CDPRO2 Group Project (open source project) - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th August 2004, 10:56 AM   #31
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Originally posted by batee
Where can I find a display like that? I see "Optrex", but there were several hundred hits on Digikey.
Looks like VFD, but schematic says LCD. Anyone have a part number or description of that technology?
Thanks,
Bryan
It is an lcd:
http://www.optrex.com/Products/PartD...1505NFQJ-LB-AE
digikey:
http://search.digikey.com/scripts/Dk...136806&Site=US
mouser:
http://www.mouser.com/index.cfm?hand..._pcodeid=80504
Brian
Old 18th August 2004, 02:44 PM   #32
LeoJar is offline LeoJar  Canada
Please count me in if you can get a bulk run. ..
Old 18th August 2004, 05:24 PM   #33
Coulomb is offline Coulomb  England
Coulomb's Avatar
I would take another one or two Brian.
Anthony
I like to stay current!
Old 18th August 2004, 06:56 PM   #34
I like to take one.
Old 18th August 2004, 08:14 PM   #35
VT67 is offline VT67  Belgium
VT67's Avatar
Me too!!
Walter
Old 18th August 2004, 10:34 PM   #36
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
OK Brian,
Count me in - I can do both!
Gaz
Old 18th August 2004, 11:03 PM   #37
Default control boards
Absolutely- count me in too.
Old 19th August 2004, 03:30 AM   #38
Hi Brian;
Please count me in for one.
Regards.
Craig
Old 19th August 2004, 05:08 AM   #39
BrianGT's Avatar
Sounds like we have some more interest in this project.
Any concensus on how the control board/buttons should be done? I see two options:
Option A:
seperate buttons board
Option B:
buttons integrated with display pcb
For option B, it could be done as to allow the pcb to be trimmed and an expansion header installed for the buttons, thus allowing option A to be added if later desired.
I would like to keep this first run limited to 10-15 boards, as this is just the initial stage of the project, and I would like to see it improved on and another run of boards done.
As for what could be provided with this project:
- pcb set for control board and buttons board
- pre-programmed PIC18F452 chip with socket
- crystal oscillator for PIC along with caps
- RS232 chip with socket and caps needed
- serial connector for side of board
Another option for this project would to put a 5v regulator on the control board (would only make it a bit wider).
Please provide input, and we can work together to evolve this into a complete project.
Schematics and layout for boards I got made for my school project:
http://www.briangt.com/gallery/cdpro2-pcb
There are some mistakes in the layout, which I will correct:
-wrong footprint for pot, causing them to have to be mounted like this
-incorrect silkscreen for a couple of labels on the output pins (reversed labels for IR and Buttons headers)
-misaligned headers connecting to LCD, see this again.
These problems can easily be fixed and more features added.
As for the power supply, I foresee eventually making a pcb for the +5,+9 needed for the transport and also for the +5 for the control board, along with relays for proper power up on the +5 and +9 for the transport.
For those who missed the earlier post, see the first post for the current C code for this project.
Here is a quick assembly guide that I made for this project, for the kits that I mailed Peter Daniel and Anthony:
http://brian.prohosting.com/assembly/
note: these instructions account for the errors in the layout, which will be corrected before any more boards are made.
Wiki for expressing interest in this project:
http://www.diyaudio.com/wiki/index.php?page=cdpro2
I will not be providing cdpro2 units, as they can easily be purchased in the US from ENCO Group:
http://www.enco-group.com
or in Europe from Nico:
http://www.daisy-laser.nl/homeoptics/
Please note that if you want a fully functional kit, Nico is currently offering one on the above website.
Also, the control board/button board for this project isn't strictly limited to the cdpro2. It is essentially a PIC18F452 development board, which could be used for many other tasks, such as controlling a volume control like the APOX units did. My intent is not to compete with the APOX units, but provide an open source development environment for the cdpro2 and other projects.
Good picture of current control board layout:
http://brian.prohosting.com/assembly...controlpcb.jpg
Any input is appreciated.
Brian
Old 19th August 2004, 06:32 AM   #40
Rarkov's Avatar
Hi all,
I'll tell you what I really like the sound of is a single optical encoder (as you've made provisions for on your board). That gives you:
Play / Pause
Next / Prev track (if you click it slowly)
Search Back / Forwards (if you twist it fast)
It requires interrupts but you have also done that so it should be possible.
Gaz
New open source loudspeaker design program project started Karoliina Multi-Way 33 10th December 2009 10:18 AM
Let's create an 'open source' hardware project. gmarsh Digital Source 41 6th October 2006 12:42 PM
Open-source DSA project borges Digital Source 8 24th September 2006 07:26 AM
Copyright 1999-2017 diyAudio
