| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
Thank You Rarkov, that's my point. There's no programming datasheet available (while pinout and block diagram are documented!). For this reason, my plan involves connecting the new controller to the old one and letting it "sniff" on the serial port. This way, I could determine the protocol (by trial and error, but I assume it's I2C) and let the new controller "learn" the old one's language ![]() So let me ask my original question in another way: Would the controller hardware and software discussed in this thread be suitable for connection to an I2C drive (I don't want to study the entire source code just to find that out)? Thanks, Sebastian. |
#22 | |
diyAudio Moderator Emeritus
-- Brian |
#23 |
Hi BrianGT,
I'm in the process of designing the "supply sequencer" by using some transistors as switches. The main issue is how to get negative voltage from the pic that could only provide 0 or +5V. But for the DAC I'e got a negative voltage (-15V) that needs to be sequenced as well. Do you have an idea of ho to do this ? Attached is a schematic to explain how using transistors as switches instead of relays. Moreover, I need your background regarding the connectors you used to for the CDPRO. While looking at the datasheet, I noticed that the connectors on its board are "JST" CMS types. I bought a set of connectors with the CDPRO unit, but I got only connectors for the unit and not for the CI of the controller board. What kind of connectors do you use for your contoller board ? I found the JST types in EAGLE while routing the board but there are only CMS types. I would be grateful if you help me in choosing the "female" connectors that has to be used on the board. Regards |
#24 |
Just to let you know, with APOX Controls' permission, I have started to rewrite the code to support the DSA protocol. I'll let you know how it goes... Gaz |
#25 |
Brian what about a soft button power on function? The front panel would always be on, but in standby. At the touch of a button or the eject function currently included, the power could be switched on sequentially to any number of relays that would power up the drive and DACS and bring the front panel out of sleep mode.
Regards Anthony
I like to stay current! |
#26 | |
I would rather see relays used for the power supply, rather than transistors. This would make life easier. A few control lines, or a serial IO expander could be used to control the relays. This would be a cleaner implementation. Relays aren't that expensive that it will be much of a worry. -- Brian |
#27 | |
-- Brian |
#28 |
If anyone is interested, I can get a run of control boards made for the cdpro2 project. I will get them made at my cost, and if we can get 10 people or so interested, they should be under $20 a set for a buttons control panel and main control board. I could include chips pre-programmed with the serial bootloader and cdpro2 code. This would allow for very easy updating of the code using a normal terminal software program.
I would like to see this project go somewhere, and keep it public domain. picture of the current control board, which is the same dimensions as the Optrex 2x20 pcb. The Apox board could work good, but it is quite big and bulky. size comparison: http://www.apoxcontrols.com/images/APOX-display.jpg -- Brian |
#29 |
Where can I find a display like that? I see "Optrex", but there were several hundred hits on Digikey.
Looks like VFD, but schematic says LCD. Anyone have a part number or description of that technology? Thanks, Bryan |
#30 | |
If you don't measure, you don't know. |
| New open source loudspeaker design program project started | Karoliina | Multi-Way | 33 | 10th December 2009 10:18 AM |
| Let's create an 'open source' hardware project. | gmarsh | Digital Source | 41 | 6th October 2006 12:42 PM |
| Open-source DSA project | borges | Digital Source | 8 | 24th September 2006 07:26 AM |
| Page generated in 0.14808 seconds (73.73% PHP - 26.27% MySQL) with 11 queries |
