| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi!
I've an old 10 years VRDS10 and I'm changing some old caps for new one (power supply and coupling/decoupling caps first). I use it only as drive. I've a question concerning the digital output. I've found in the digital output circuit an 0.47UF + 100nF caps used to couple signal to the next stage. Do we have a way to improve this or not? What's the best? Just change the 0.47UF for a new one or another solution? I've enclosed the schematic and wrote a red circle to show. Thanks for your help and ideas. |
#2 |
IMO it's safe to replace with a single 0.47uf film capacitor (WIMA MKP), check for the distance between the holes in the board before you buy it.
Deep down inside. |
#3 |
The PCB est standard. Most the hole are 5mm. The problem is more W.
I'm not sure that 0,47UF exist for MKT or FKP series. We can may be replace both 0.47UF and 0.1UF by an unique 0.1UF polypropylene caps? I'm thinking to MKP1837 serie from Wishay. |
#4 |
Here's a good search engine: Farnell UK website search for 0.47uf
You want to know if you can replace 0.47uf+0.1uf with 1uf I suppose... Either 0.47uf alone or 1uf will do.
Deep down inside. |
#5 |
The UK Farnell search engine is realy great. We don't have this in the French site (who is slow too).
Unfortunaly, a 0.47UF polypropylene caps from Wima MKP4 is realy too big to fit, and I'm not sure that this kind of caps is occurate to couple digital signal. Wishay MKP1837 stop at 0.1uF and Wima FKP2 at 10nF. |
#6 |
Hi
Forget about upgrading this path Buy a new clock and apply reclocking at the digout of the CDX2500 processor cheers |
#7 | |
Just to know. I've see on the XO3 version a "clock output". Is it something as a master clock? I have an DEQ2496 from Behringer. This unit have a master clock input. Does, the XO3 clock output will work with that? |
#8 |
You don't need to spend 150€ to reclock spdif. You can build your own reclocker.
Get a flipflop, separate buffer and connect the current clock, you don't even need a board as it could be hardwired. |
#9 | |
Banned
You can build this tranformerless interface. If you want a transformer it can be placed at the DAC-end before the comparator. Both the Scientific Conversions SC944-05 and the Pulse Engineering PE-65612 work well. Any reclocking should be placed after the Digital Inputreceiver or in case of a digital filter after the latter as these are the main sources of jitter if you have mastered to control the reflections in the cable.
#10 | |
Banned
Hi A8, My experiments did show that reclocking the SPDIF output with the masterclock of the CDP produced no improvement. ![]() But of course YMMV........... |
| digital crossover w/digital output? | ezkcdude | Multi-Way | 30 | 3rd August 2006 01:01 AM |
| Vrds10 - Jumping | ANDYLASER | Digital Source | 11 | 16th July 2006 11:52 AM |
| Get digital signal from an old CD-Rom without digital output | genome | Digital Source | 5 | 3rd February 2004 11:54 PM |
| I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output | iklari14 | Digital Source | 30 | 18th July 2003 12:57 PM |
| Page generated in 0.11409 seconds (78.74% PHP - 21.26% MySQL) with 11 queries |
