| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi
I am trying to connect the I2S output from my DIY CDPRO2 player to the Perpetual Technologies P-1A DAC I2S input. My problem is that I'm not sure what clock/data connections from the CDPRO2 (see table below) to use so that it matches the I2S P-1A connector. cd pro2 I2s output: pin1 EF=====C2 error flag pin2 SCLK===serial clock pin3 WCLK===word clock pin4 DATA===Data pin5 GND====ground pin6 V4=====Versatile output Hopefully, I have attached a diagram of what i believe is the rear view of the Perpetual Technologies P-1A I2S connector. Could someone please advise what connections from the CDPRO2 (table above) I should use to connect to the P-1A. I guess the obvious ones are: CDPRO2 pin2 SCLK==serial clock to P-1A serial clock pin CDPRO2 pin4 DATA===Data to P-1A Serial Data pin CDPRO2 pin5 GND===ground to P-1A ground pin The remaining outputs I don't know or even if there are needed. Any help appreciated. Thanks |
#2 |
You need to connect WCLK (Word-Clock) too. It's named LRCK, WCK or something like that ...
Maybe your OS-Filter or DAC needs MCLK too (in most cases 128, 192, 256, 384 or 512 x fs) ... Regards Jobstens |
#3 |
I know this thread is OLD (!) but did you ever get this working? My PT P1A and P3A are sitting gathering dust because I could never get any sound via I2S...
Thanks |
| Input pot question | kacernator | Tubes / Valves | 9 | 1st April 2008 03:10 AM |
| another input cap question for SI t-amp | schumpe | Class D | 27 | 10th July 2007 10:20 PM |
| pre amp question, need your input | cidme | Everything Else | 4 | 2nd July 2007 07:40 PM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Zen input question? | MikeW | Pass Labs | 4 | 7th December 2005 05:13 PM |
| Page generated in 0.06832 seconds (70.97% PHP - 29.03% MySQL) with 11 queries |
