Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Is2 possible with this dac?
Old 10th July 2004, 03:44 PM   #11
wazzup is offline wazzup  Netherlands
Send a message via MSN to wazzup
cd pro2 is2 output:
pin1 EF=====C2 error flag
pin2 SCLK===serial clock
pin3 WCLK===word clock
pin4 DATA===Data
pin5 GND====ground
pin6 V4=====Versatile output
Then the Receiver imput:
pin1 DEM0-------pin20 DIFo
pin2 DEM1-------pin19 DIF1
pin3 VA-----------pin18 AOUTL+
pin4 AGND-------pin17 AOUTL-
pin5 DGND-------pin16 MUTE L
pin6 VD-----------pin15 MUTE R
pin7 LRCK--------pin14 AOUTR+
pin8 MCLK--------pin13 AOUTR-
pin9 SCLK--------pin12 DIF2
pin10 SDATA------pin11 AUTO-MUTE
So I would connect from the cdpro :
pin 2 to pin 9 -SCLK to SCLK-
pin 4 to pin 10 DATA to SDATA
pin 5 to pin 5 GND to DGND
ANd thats it? Connect it and it works?
Btw what cable should I use for the connexion?
"I`m not the messiah!"
Old 10th July 2004, 03:51 PM   #12
Aha I see that some new replies have been send!
Ignore my previous post -a bit - I wrote it last night, but just posted it 5 minutes ago.
Mmm do there are a lot of different DSA modus? I will look into that on daisy-laser.
I still haven`t figured out where the word clock goes into the dac chip.. First I`m gonne study all the replies a bit better.
Tnx again all.
Old 13th July 2004, 08:50 AM   #13
Originally posted by till
The CD PRO2 could be told by a DSA command from the controller what format it should send to the I2S bus. There are 16 or so different formats it could send.
Mmm I have looked at all the cd-pro manuals, and I can`t seem to find any info HOW to make the controller -or external device- send to the cd-pro to go into that specific Is2 output.
Any ideas anyone?
Old 14th July 2004, 07:35 PM   #14
Bruce Lee.
Old 14th July 2004, 08:14 PM   #15
rfbrw is offline rfbrw
Any ideas anyone?
The specs are on the daisy-laser site.
Old 14th July 2004, 08:30 PM   #16
till is offline till
Banned
http://www.daisy-laser.com/products/.../downloads.htm
http://www.daisy-laser.com/products/...P10501_dsa.pdf
----> page 31:
3.26 Set DAC mode (I2S output format)
This command sets the I2S output format. The command will be executed directly for the mode
selected previously by 'SET MODE' command, otherwise it will be saved internally.
command: Set DAC mode 70h / <I2S mode>
response command: DAC mode 70h / <I2S mode>
<I2S
mode>
I2S format mode
see SET MODE command
0 reserved
1 I2S - FS mode (default) DAC mode
2 I2S - 2 FS mode DAC mode
3 I2S - 4 FS mode DAC mode
4 Sony 16 bit FS DAC mode
5 Sony 16 bit 2 FS DAC mode
6 Sony 16 bit 4 FS DAC mode
7 Sony 18 bit FS DAC mode
8 Sony 18 bit 2 FS DAC mode
9 Sony 18 bit 4 FS DAC mode
81 I2S - CD-ROM mode CD-ROM mode
82 EIAJ CD-ROM mode CD-ROM mode
these should be the formats of data the transport could deliver on the I2S bus
Old 14th July 2004, 08:36 PM   #17
Right... How to connect it to my computer is on the SITE. Not in some pdf.
I completly overlooked.
Tnx Till, and Rfbrw.
Is2 possible with this dac?Hide this!Advertise here!
