| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hey...
On my continued dac quest (and having realised the pin spacing on a PCM4104 ) the PCM1794 presented itself. As i'm after balanced outs would this circuit be okay? It uses the same i/v stage (using NE5534s) as on the application datasheet and a OPA1632 for a fully-differential output (that part from 1404 datasheet)... Do I need to do anything else - i'm really wingin my way thru all this... Cheers. |
#2 |
Why do you have 100k resistors on the outputs???
I recommend you read through this thread Best opamp for I/V conversion? (DAC) before deciding on the 5534's. The OPA1632 is a very good idea though. |
#3 |
Why just not use the TI spec sheet for the PCM1794? or are you just wanting balanced out from one chip and not two, used in mono?
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#4 | |||
So, goin on schem as is - will it work? Regards Thanks |
#5 |
I mean are you wanting to use only one dac chip and not two. So you want to use a stereo output from a single chip but get balanced.
Actually using these chips is a piece of cake, there is no reason why not to use two PCM1794's in mono mode. Obviously you need more opamps and chips etc so it will cost more, so if that is an issue then it makes sense to use one PCM1794. But appart from cost. I built my first DAC (still quite new in the digi threads) to see if I could get it to work. If I make another one I think Ill use AD's upsampler and two PCM1794s on the output. Obviously this will give me balanced which I wont actually use but it cant hurt to have a chip on each channel.
#6 | ||
#7 | |
![]() I think you should remove the 22pF cap. It is only there in the datasheet because of the voltage output of the PCM1804, not functional when you use I/V converters. Other than that it should work great! Build it and keep us updated! And yes you will get balanced stereo out of one PCM1794 with this circuit. |
#8 | ||
![]() Quote:
#9 | |
#10 |
Hi!
Some idea to utilize mono balanced mode of those DACs (PCM1798 and PCM1794 are similar) with balanced I/V converters. This thread Basically 1 DAC = 1 channel BR, |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Page generated in 0.09756 seconds (88.33% PHP - 11.67% MySQL) with 10 queries |
