PCM1794 output stage - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th July 2004, 10:48 AM   #11
Heyhey...
Nice, I've updated the PDF link following some of the advice here . So, I think i'll go with this circuit initially and if all is dandy try a 1dac per chan brd to see if theres any major dif...
A discrete i/v stage followed by a DOA (mebbe some iron too) would be lovely tho - it's just the expense/knowledge I lack there to implement correctly I think...
Thanks > again.
Old 8th July 2004, 02:02 PM   #12
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Another pdf ;-) with some iron
http://www.kevinc927.addr.com/images...utputstage.pdf
Old 8th July 2004, 02:32 PM   #13
borges is offline borges  Norway
Congrats on your design!
I'm using the PCM1794 with my own oversampler (Xilinx demo board) to compare it to the PCM1704. I've got a 2nd order filter on a pair of 1704's and on the R outputs on a pair of 1794's. Then I've got a different filter on the L outputs on the same 1794's. According to TI/BB, the two types of DAC accept the same input data format.
Did anobody out there ever try using a passive IV converter on the 1794? I just need to run a few more simulations to determine my component values before I solder mine in. I hooked up four bias current sources based on 431's and big surface mount NPNs to remove much of the 6.2mA DC output current.
Besides, TI/BB could easily have been more instructive on the polarity of the different outputs when using the device in mono mode. I should have read the referred thread before designing my board, because now at least half my outputs are inverted.
Greetings,
BÝrge
Old 8th July 2004, 02:37 PM   #14
Hey Bas...
That looks nice...
So the i/v stage (just a few transistors?) in that pdf is powered by it's own tx and psu circuit - really needed? Im after 8 chans in a single box.
It looks nice n simple tho (am i missing summin) u just go from the dac (1794 here) outs to where it says ye? No opamps at all in the signal...
Cheers.
Old 8th July 2004, 03:08 PM   #15
pooge is offline pooge  United States
Greetings,
BÝrge
K&K is coming out with a passive output with resistor I/V and transformers:
http://www.kevinc927.addr.com/digitalaudio.html
Old 8th July 2004, 03:10 PM   #16
Project development history
http://www.audioasylum.com/forums/Ka...ages/2397.html
I suppose that tx could power 8 channels..the rest of the psu would need to be multiplied.
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 12:14 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Copyright ©1999-2017 diyAudio
