| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a question regarding the PCM2902 chip. What I want to do is using it for a USB->SPDIF converter. I've read some articles regarding powering of the chip, where it has been recommended NOT to use the USB voltage, but this is all in cases where people have built the USB-SPDIF-device with the chip's integrated DAC capabilities, wich I will NOT be using.
So... In cases where the DAC section of the PCM2902 is NOT used, is there any noise problems with powering the circuit from the USB line, and then maybe wire my DAC ground to the USB ground with a small resistor value like 10 ohms or something to keep noise down? I am thinking this will not be a problem as the SPDIF signal is still digital...? |
#2 |
I guess it would be something like this:
#3 |
Overwhelming response.. Well, if someone has something sensible to say about this matter somewhere in time and space, please let me know. I guess I'll just have to figure this one out myself.
#4 |
I made something similar to this however I fried the PCM2902 by mistake. With this in mind I cannot offer any helpful comments on how well it works. But I am going to use it off the 5v USB supply with the grounds all wired to the star earth. Im waiting for another chip to arrive and will comment on it when it does. But until then I think it will work fine. MWP made it in pretty much the same way and had good success.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#5 |
Thanx 5th. I've read your DAC thread, and I've also looked through some of MWP's DAC work. Thank you for the star ground tip, I'll test it versus a resistor I guess.
With this circuit one can get quite a number SPDIFs very cheap, but are there any software filters that can utilize USB (Windows or Linux)? |
| Can't get PCM2902 to work | Limhes | Digital Source | 5 | 3rd May 2008 02:26 AM |
| Wtb: Pcm2902 | Kovax | Swap Meet | 0 | 31st May 2006 07:37 PM |
| PCM2902 difficulties | jmar | Digital Source | 7 | 13th January 2006 09:07 PM |
| USB DAC w. PCM2902 - no input in SW | kims | Digital Source | 1 | 7th November 2005 04:56 PM |
| Op amps on PCM2902 DAC | jmar | Digital Source | 4 | 4th May 2004 05:48 AM |
| Page generated in 0.08397 seconds (72.89% PHP - 27.11% MySQL) with 11 queries |
