| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 |
Jason, when would it be possible to include more images in one post ?
François "Learning French is trivial: the word for horse is cheval, and everything else follows in the same way." |
#42 |
was just looking through this thread again as it has some great info.
those latest impedance plots look fantastic. i wonder if large-value SMT ceramics are the way to go. how about those Specialty Polymer electrolytics, like the Panasonics? any idea how those would perform? i am thinking of building a SACD player based on parts from a Sony changer so i am definitely into power supply optimization techniques for digital and mixed-signal supplies. i am probably stuck with the stock Sony digital board, which has all the transport and DSD processing stuff, but the DAC/analog stages are up for grabs. |
#43 |
Haven't had enough time to simulate ths SP Caps, but at first glance, they seem to have a (not much) larger capacitance than ceramics, but sure it's worth a try, despite the cost of these SP caps
![]() I'm currently finishing some test PCBs to be able to compare the different decoupling schemes. Basically, I'll try to monitor the voltage before and after a 78L05 V reg supplying a HC393 counter (SO Package) fed by a 50 MHz clock. As I have no access to impedance meter or network analyzer, I won't be able to speak about impedance curves. But I will measure supply noise with a 2GHz spectrum analyser with different caps/chokes/coils combination. Stay tuned, but I have to find the time to do it.... In a week or two...
#44 |
Slightly offtracks, found a rather nice page which provides some useful insights on noise reduction and EMI supression. And back on the track again, they speak about capacitors, with emphasis on ESL issue... And funnily, they come to the same kind of conclusions (now you know why I post this
![]() Enjoy
#45 |
Thanks to ftorres for the enlightening simulations.
Some years ago, I measured a similar doublet with 47uF smt tantalum and 22nF 0603 X7R ceramic. The peak that you found in your simulation with the 100uF Rubycon did not appear. With the smt tantalum the "trough" was flat until a few MHz before the 22nF resonates at around 11MHz. So with a smt tantalum you could probably reduce that back to a triplet. The lowest ESR hi-value caps that I hv come across are the AO series from Kemet and the Poscaps from Sanyo. Both these can be operated AT the rated voltage, no derating required. Also, if the voltage across them exceeds rating for an extended period, they do not catch fire, just some smoke and an open ckt results. Both are polymer tantalum types. Off the top of my head, the Kemet ones for 47uF weighs in at about 30milli ohm ESR. These are both smt types. If you want to prevent noise from getting into your supply lines, you could also use 3-terminal caps which are a sort of straight wire with a built-in filter capacitance. These are available in the Murata website below. (lots of emi simulation help too). http://www.murata.com/emc/product/chip_idx.html Look under Chip Solid "emifil". Keep up the great info flow foks. Yv |
#46 |
... that should have been a 47uF smt and 220nF doublet,
not 22nF doublet. Interestingly, the resonance at 11MHz due to the 220nF ceramic correlates well to ftorres' simulations. Yv |
#47 | ||
Yves, (French firstname, french man ?)
Thanks for your comments. Quote:
But I'm gald to see they do not give totally absurd results By the way, what did you use to make your measurements ? For the moment, I've given up with simulations, and I'd rather make some measurements. As you may have noticed from my previous posts, I can not measure impedance, so I will try to get the frequency spectrum of a digital supply line, before and after a Vreg with different bypassing schemes. But availability problems have reduced my ambitions I couldn't get hold of 270nF or 220nF 0612 smt caps, and the higher value I have is 100nF in this package. Same story with PosCaps, but I can manage to test Panasonic SP Caps, Sanyo OS-CON smt, and tantalum smt caps (cannot find the Kermet's AO series here)Quote:
I should have some results to post next week, provided I can have the spectrum analyzer working, and GPIB as well, since display's photographs are not quite gorgeous... Thanks again for your advice and comments.
#48 |
Hi ftorres,
I still believe simulations give a good idea of first order performance, as you probably know well enough. The measurements I made were with a Agilent (was HP) 8753C network analyser with matched impedances on pcboards that were good up to a few GHz. Unfortunately, they start at 300kHz (Instrument limitation), but I guess that this may be ok since the resonances don't become nasty until above that freq. When I get the time I will try to make some more new measurements. Does anyone know what are the nastiest frequencies that are around in the psu lines and analog ckts? I would suspect 256x, 512x of 44.1kHz and crystal freqs are the main culprits cheers |
#49 | |
Yves,
Thanks for the infos. Quote:
Were the matched loads in parallel or in series with the capacitors (sorry for the maybe dumb question, but I'm not familiar with network analyzers and this type of measurement ) ?Concerning the frequencies, I've got little clues. I couldn't resist to quickly solder a test circuit to see what was awaiting me in front of the spectrum analyzer. Just for memory, the circuit is a 50MHz canned clock driving a 74HC393, thus dividing the clock signal by 8. Clock and HC393 have their own Vreg (L05), each one being fed by a 9V battery, with only common ground. This test circuit was breadboarded in an ugly way (wires everywhere, no ground plane, no SMDs, minimal decoupling), just to see what happens. And I've not been disappointed I've now to wait for the real pcbs to be etched, to get nicer results (at least I hope )
#50 |
Hi ftorres,
The loads were actually part of the network analyser input and output impedances and the measurements were made with a transmission line that is the same impedance with the terminations. You can think of the source as a Thevenin voltage with the same output impedance as the load that is shunted to ground with the same impedance. The impedance in this case is 50 ohms. You can use any other impedance since the plots are all in dB. I guess this is one of the priviledges of the job ![]() Manufacturers usually like to show off their cap bypass capabilities with the kind of circuit you tested with. I am pretty impressed by the low ESR caps in the market nowadays, good for us that EMI is such a hot topic. rgds |
| V regulation for digital circuits | DECKY999 | Digital Source | 9 | 28th March 2008 04:16 PM |
| Decoupling caps-Alternatives to tantalum capacitors in digital circuits? | Dr.H | Digital Source | 20 | 21st February 2005 05:01 PM |
| Voltage regulators for line level circuits | HarryHaller | Solid State | 64 | 24th April 2003 05:45 PM |
| Capacitors for digital circuits- Tants vs electrolytics | Dr.H | Digital Source | 7 | 12th February 2003 03:21 PM |
| Sulzer Regulators vs LT1085 in digital circuits | Dr.H | Digital Source | 0 | 29th July 2002 05:56 AM |
