Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th July 2004, 11:48 AM   #1
Default PCM4104 DAC PCB Layout
Hi...
I've layed out a single sided design for a balanced output PCM4104 4 channel DAC. The idea is to link the A and D gnds via the gnd pins of those 2 caps over the dac chip (u'll see in the design) on the top layer with a strip of copper or summin...
Any comments from the knowledge out there on the layout?
PCM4104 DAC PDF
Old 4th July 2004, 11:21 PM   #2
Hi there! nice layout.
I can't answer your question but as I have understand it it should work well? I also want to hear from the gurus some tricks with groundplanes.
Your solution is simular to mine, I think?
/Tobias
Old 5th July 2004, 04:44 AM   #3
jobstens's Avatar
Ehhm ... I'm right - the both capacitors are directly on the backside of the chip ? where are the legs of them ? I think you haven't enough space for them ...
Hint: you must desolder the DAC to resolder the both capacitors in case of cold solderings (because they must be flat) ...
DGND <-> AGND connecting
If you build two seperate powersupplies (D and A), you maybe could place ~10 Ohm or a coil (or both in parallel) between the two grounds. Don't connect both grounds in the powersupply.
If you design a powersupply for D+A with one ground, connect both grounds of the DAC short as possible and place the ground-connection from the powersupply short as possible to the DAC on the A-side.
Jobstens
Old 5th July 2004, 02:00 PM   #4
Hi...
well, the dac is on the bottom layer and the 2 caps would be on the top. The red wire in the top layer legend indicates where i'd stick some copper strip, then the 2 gnd legs of those caps would be soldered on both top and bottom (joing the gnd on top) - as long as the bottom is soldered flush to the board the dac should sit happy no?
Speaking of the psu...heres a PDF schem. Nothing to fancy but any comments still be good...
Cheers.
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 10 8th October 2012 06:13 PM
Whose layout is this? Ulew Chip Amps 9 14th December 2008 02:33 PM
pcb layout jamesrnz Power Supplies 0 9th March 2008 12:42 AM
One more P 1.7 layout...... Kari Pass Labs 7 11th February 2006 03:00 PM
Possible GC layout? lazyfly Chip Amps 4 22nd August 2004 04:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
