Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th July 2004, 11:33 PM   #11
Well, after looking at it, I'll be choosing parts. Only part that I'm unsure of is the clock. What I plan on using to convert from i2s to S/PDIF is a DIT4096. Thing is, I need two extra clocks. First clock is the main clock, at 1.4112MHz which clocks the counter and binarey clock line. Second clock is The master clock to clock the DIT4096. I am not experienced in designing a PLL. Can I use a higher frequency crystal and use a counter to divide the clock? If I use a crystal that outputs a sine wave, I'll need to use some sort of IC to convert it to a square and divide the clock.
Thanks.
Old 11th July 2004, 11:55 PM   #12
jobstens's Avatar
a 4040 will do that
Jobstens
Old 11th July 2004, 11:57 PM   #13
jobstens's Avatar
Sorry, the 4040 will devide the 11.2896 or 22.5792 MHz by 4 or 8 to the needed 1.4112MHz (which is 44100*32)
Old 12th July 2004, 12:16 AM   #14
Banned
what about making that I2S with a microcontroller and convert it with your DIT to SPDIF?
but same again, for the I2S signal you want, also first please a timing diagramm.
Old 12th July 2004, 12:36 AM   #15
jobstens's Avatar
It's me again ...
you don't need to delay the data for 1 bit to use i2s. the DIT4096 accepts left justified data with 0 SCLK delay (see page 7 in the manual) ISYNC should be set to 1.
Build an osc. with 11.2896 MHz
This is MCLK to the DIT
This goes to the 4040 too.
On Q2 (Pin 6) you got your SCLK (1.4MHz),
Q3-Q6 from 4040 equals to Q0-Q3 in the EPROM circuit
Q7 from 4040 is Q4 = LRCK (44.1kHz)
LRCK goes to a second 4040 which generates Q5-Q13 (Output on the second 4040 = Q0 - Q8). With D1 you are reseting only the second 4040 - but you must inverting D1 or I do in a new binary (attached)
Could I remove all clarities ? ;-)
Jobstens
Old 12th July 2004, 01:26 AM   #16
jobstens's Avatar
You asked for it ;-)
enjoy it !
Jobstens
Old 12th July 2004, 02:01 AM   #17
enjoy it !
Jobstens
Old 12th July 2004, 02:31 AM   #18
jobstens's Avatar
Emuman - here is a new version of the circuit ...
Jobstens
Old 12th July 2004, 04:23 AM   #19
jobstens,
You are a genious! I think you should assemble this too. I'll make a digikey parts list tonight. THANK YOU SO MUCH!
Old 14th July 2004, 05:22 PM   #20
You would be better served considering the instruction cycle time of the microcontroller you intend to use.
Tube Tester's Space1 Tubes / Valves 17 2nd June 2009 08:54 PM
DIY My tube tester sjh327 Tubes / Valves 0 30th November 2008 02:25 PM
WTB Woffer Tester woody Swap Meet 1 17th March 2008 09:52 PM
Have you seen this tester? smak Tubes / Valves 30 28th January 2006 06:43 PM
tube tester TJ Tubes / Valves 11 5th April 2005 02:23 PM
Copyright ©1999-2013 diyAudio
