Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th June 2004, 11:08 PM   #1
Oli is offline Oli  United Kingdom
Default Shield the reclocker unit or not?
My current DAC project:
CS8412 receiver
Kwak Asynchronous reclocker
AD1865N-K DAC
OPA627 I-V conversion (I like this- I know some do not)
Whilst doing a PCB design I have the opportunity to shield the entire reclocker circuit (crystal, coils, flip-flops etc.) using a steel rf shielding can from Farnell.
My question...
Should I do it?
Can anyone give provide reasons for or against shielding the circuit?
Oli
Old 28th June 2004, 11:25 PM   #2
BrianL is offline BrianL  United States
I don't think it would hurt as one wants to keep digital hash
out of the analog.
bel
Old 29th June 2004, 12:09 AM   #3
Default Thanks for your opinion
Thanks for your opinion- I share this view, although there are folk out there who believe shielding is a bad thing (NVA amplifiers)
Oli
Old 29th June 2004, 10:21 AM   #4
Andypairo's Avatar
Do it, I had some troubles with RF emissions from the canned oscillator I used in the ASR of my last DAC...
Cheers
Andrea
Old 30th June 2004, 01:46 PM   #5
Pitch254's Avatar
Default Shield
Prefferably use cupper and or tinned metal. Steel doesn´t shield much when it concerns mHz or higher frequencies.
Old 1st July 2004, 07:55 PM   #6
Banned
Old copper-clad works good.
I would build it without it......and use a TV set as a cheap spectrum anaylser to see how much it really radiates.
Wouldn't hurt to leave room on the PCB if it does............
Jocko
Old 1st July 2004, 09:32 PM   #7
Banned
Send a message via Yahoo to Elso Kwak
Thumbs up Shielding
Jocko
Hi, I would shield it as Jocko does recommend.
I could receive the reclocker to back in the garden on my Walkmen. And I have a deep garden!
Old 1st July 2004, 10:50 PM   #8
Default A drop-in solution is available in steel!
Jocko, Elso and others...
Thanks for your recommendations. With my prototype I see an inteference pattern whilst watching TV! The reclocker also serves as a powerful r.f. transmitter. It seems all agree that shielding is a good thing. The r.f. boxes from Farnell are steel with a solder coating, making them easy to solder. I suppose I should solder all the way along the joint with the PCB to ensure good screening and ensure a short ground loop (as per Guido Tent's ideas).
Fact: Steel is magnetic and does not conduct as well as copper.
Q. Would copper really offer a significant improvement, since a drop-in solution is readily available in steel?
Ideally I should try both copper and steel, but the box will be soldered all the way along the joints, making it nearly impossible to remove from the PCB.
Oli
Old 1st July 2004, 10:59 PM   #9
Banned
Default Probably not the reclocker.......
But your clock.
The harmonics of the SPDIF usually are not strong enough to see on a TV set. But the clock harmonics are. Try using coax for the clock feed, and see what happens. Bypass the DC coming into the unit, as the DC lines can also radiate clock harmonics.
Jocko
Old 1st July 2004, 11:27 PM   #10
Default Interesting link
Just reading an interesting link on TNT-Audio...
Wood is good!
Clearly wood is no good for a reclocker box, but perhaps I should avoid steel and build a copper box?
More work!
Oli
Toroid transformer, shield or not to shield? bays_9a5tt Digital Line Level 10 21st December 2008 02:10 PM
Synchronous Reclocker. Feedback please riotubes Digital Source 10 15th March 2007 02:20 PM
Good recklocker and crappy reclocker darkfenriz Digital Source 1 3rd November 2006 05:17 PM
Kwak async reclocker DragonMaster Digital Source 1 20th August 2005 08:02 AM
Page generated in 0.09741 seconds (79.68% PHP - 20.32% MySQL) with 10 queries
