Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
SBLive improvement
SBLive improvement
Old 30th June 2004, 07:19 AM   #11
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
OPA2134 (@vitacom in Romania) is a better replacement for the opamps than the OPA2604 as the PS for the TL072s is most likely +-12. Also shunt output coupling caps (crap electrolytics) if you go this way, but only if you get less than 10mV of DC offset on outputs.
5th element: Some older Live! models had ~5V pp on SPDIF instead of the standard value, so make sure you don't fry the receiver chip on the DAC.
We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines. Measurements can provide a measure of insight, but are no substitute for human judgment. Nelson Pass
Old 30th June 2004, 09:39 AM   #12
carlosfm is offline carlosfm  Portugal
Banned
Originally posted by lucpes
OPA2134 (@vitacom in Romania) is a better replacement for the opamps than the OPA2604...
Yes, I also prefer the OPA2132 (same thing but more expensive...) to the OPA2604.
But at the time I only had OPA2604s in SMD and I used those.
Not easy to change, as you can imagine.
...as the PS for the TL072s is most likely +-12.
If I remember (this must have been some 3 or 4 years ago), it's much worse than that.
From the +/- 12v it regulates to +/-5v on the SB, and it's this voltage that is present on the op-amps' pins.
The OPA2604s didn't like this at all (they work much better at higher voltages), and this was one of the reasons I made the PSU.
But before making the PSU I tested to feed the op-amps with +/-12v from the PC's PSU.
Miserable.
I heard the heads of the HDD moving back and forth on my speakers.
Interference everywhere.
Inside a PC is the worst place to have a soundcard.
Old 30th June 2004, 10:03 AM   #13
Agreed Anyway, to change SMD IC's take it leg by leg: for desoldering just heat & gently lift one foot at a time using a needle/pin.
Old 30th June 2004, 10:12 AM   #14
Banned
Yes, that's what I do.
But I don't feel the need to tweak this soundcard anymore, it's fine for me.
If I was to bother and loose some more time with this, the next step would be getting I2S from the original dac's pins to the outside of the PC and make an external dac.
Old 30th June 2004, 11:35 AM   #15
Bricolo is offline Bricolo  France
Bricolo's Avatar
are you sure this has been fixed on the newer models?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 30th June 2004, 11:37 AM   #16
Banned
At least my old SB Live Value works fine with my Audio Alchemy DDE v3.0...
Old 30th June 2004, 12:09 PM   #17
Bricolo's Avatar
I don't know what reciever it uses, but from what I've read here the CS8412 is more than happy with something higher that 0.5v pp
Old 30th June 2004, 12:38 PM   #18
Regarding the 5V issue, here's some more details (the signal on the Live! seems to be TTL)http://www.andrewkilpatrick.org/mind/spdif/
I don't know more about it, I don't have a Live! around anymore.
Old 30th June 2004, 01:54 PM   #19
Banned
On the 3 1/2" digital out plug at the back, it is SPDIF.
Internaly, on the board, you have the pins where the drive bay connects, with a flat cable, and you can get digital out from there, but those are TTL.
Old 30th June 2004, 07:08 PM   #20
5th element is offline 5th element  United Kingdom
5th element's Avatar
Well the DIR1703 can handle 6.5v pp so I guess im OK.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
SBLive improvementHide this!Advertise here!
Room for improvement shatt3r Car Audio 0 17th November 2005 06:26 AM
SBLive Upgrade and Modification? bezobraznia Digital Source 10 18th June 2005 11:10 AM
Do these braces need improvement andy2 Multi-Way 19 11th May 2005 06:41 PM
To Nappylady on the KX and the SBlive and anyone else 5th element Multi-Way 6 9th September 2003 11:59 PM
