Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Drawing of I/V converter
Old 18th May 2002, 02:28 AM   #11
Electro is offline Electro
The 50K R11 is the attenuator.
Its not a attenuator. It is a regular resistor. The pin two of R11 is unused.
Old 18th May 2002, 02:42 AM   #12
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Don't pick nits. I used the symbol b/c its in the library. The attenuator isn't a pot, it's a stepped attenuator with 24 positions, where V+ is connected to GND and V- is connected to OUT. Sound backwards? Think it over for a while.
[ time passes ]
I only need two terminals of the attenuator because it works backwards in this circuit compared to a normal attenuator circuit. With the switch all the way up, I want the maximum resistance, and with the switch all the way down I want zero resistance.
Old 18th May 2002, 04:29 AM   #13
Sounds lazy because you didn't draw it correctly.
Old 18th May 2002, 05:30 AM   #14
jwb's Avatar
I'll be sure to report back here if that has any effect on the audio quality.
Old 18th May 2002, 06:23 AM   #15
tiroth is offline tiroth  United States
Originally posted by Jocko Homo
Ignore the guy from Pittsburgh. [joke]
Jocko
:P
I've been doing some work on my own variation on the D1 theme if anyone is interested. Nothing special, but closer to normal supply voltages.
link
If the part count seems high, consider that the capacitors are really optional (but a very good idea).
Old 18th May 2002, 05:58 PM   #16
Jocko Homo is offline Jocko Homo  United States
Banned
The DAC wants to see a virtual ground, and at zero volts. How are you ensuring the latter?
Jocko
Old 18th May 2002, 08:48 PM   #17
The design is for a DAC with virtual ground between 0v and AVdd. You could use it on a DAC like the 1704 by making the circuit's "virtual" ground the real ground and adjusting the trimming resistors appropriately.
The diagram is confusing...here is an update:
Old 19th May 2002, 08:08 PM   #18
Banned
Not quite the way I would have done it. Remember I don't like MOSFETs, especially there. Should work though. Try to get the Z as low as possible. Yes, I know it will work if it is >0, but the lower the better.
(Hint: try a BJT.)
Jocko
Old 19th May 2002, 08:14 PM   #19
HarryHaller is offline HarryHaller  United States
Banned
Default Mosfet
Or you could put some feedback around mosfets gate to source to lower the impedance seen by the DAC. Or you could use inferior sounding BJTs.
H.H.
Old 19th May 2002, 10:51 PM   #20
Banned
How could you ever listen to those inferior things, Harry.
Jocko
Drawing of I/V converterHide this!Advertise here!
drawing freeware??? aardvarkash10 Full Range 12 15th May 2008 01:33 PM
CAD drawing assistance Brett Everything Else 13 11th March 2006 12:18 PM
My first GC PCB drawing... flying Chip Amps 8 14th January 2005 07:24 AM
Drawing PCB's... eeka chu Digital Source 4 7th June 2004 08:13 AM
CAD Drawing Doug Everything Else 8 8th October 2003 03:52 PM
Copyright ©1999-2017 diyAudio
