| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
is it compatible ? Use 1 x 1541 instead 2 x PCM56 ? Bernhard |
#2 | |
Read the datasheets. |
#3 | |
#4 | |
Rant on In order attain a reasonable level of competence in any arena, one has to be prepared to put in some degree of effort, however basic. And what can be more basic than reading the datasheets?. I am frequently amazed by the kind of information people expect to be handed to them on a plate, while they at the same time are not prepared to put in the slightest effort. Rant off FWIW page 4 of the TDA1541A datasheet states clearly under the heading Input data selection that the data must Offset Binary when the TDA1541A is in simultaneous mode. BTW this topic was covered in detail in the thread covering rah's circuit for connecting to the TDA1541A in simultaneous mode. Page 4 of the PCM56 datasheet under the heading Digital Input Codes states that the data for it is Binary Two's Complement. Incompatible without glue logic I'd say, wouldn't you? |
#5 | |
The timing diagrams looked so nicely the same. My idea was to put TDA1541 in a Technics player where PCM56 work back to back on halfwaves which seems to be the same as what is done in colinear PCM1702. It would be the unique oportunity to gain higher resolution with 1541 and avoid digital zero crossing distortion. There must be that glue logic somewhere on my hard disc... |
#6 | |
| Non-simultaneous Pentode anode/G2 turn-on | Klimon | Tubes / Valves | 7 | 7th November 2007 06:48 AM |
| Oversampled TDA1541(a) I2S format? | andrew_whitham | Digital Source | 25 | 17th April 2006 08:10 PM |
| Using a spdt switch to select between triode mode and pentode mode on a guitar amp. | G | Tubes / Valves | 19 | 15th March 2006 10:15 AM |
| Simultaneous regulation of +/- on switcher | jackinnj | Power Supplies | 0 | 18th February 2005 05:47 PM |
| tda1541 vs. PCM56 | Bernhard | Digital Source | 23 | 21st October 2004 11:42 PM |
| Page generated in 0.08854 seconds (87.14% PHP - 12.86% MySQL) with 10 queries |
