| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
For opamps OPA2134 - AU package or AD8620. First can be found for $3-4 the other is too expensive and not easily available.
Shunt the coupling capacitors=replace with a piece of wire (non-ferous resistance leads are great for this, or you might solder underneath the board to check). DC offset shouldn't be a problem but it's good to check at the output after mod. OPA2134 - does not oscillate, does good with the +-12V power lines, DC offset without coupling caps is very low - 2mV and 3mV and the sq is just great. Not on par with the greatest CDP/DAC but should beat the hell out of any mainstream CDP.Regarding the circuit layout - the 410 uses a different chip/DAC/ADC than the Revo, I can't remember if the front out is buffered or not, but the same 5532s for analog - locate the AKM chip - DAC and see what opamps are near to know what to replace; 470ufs for +-12V filtering should be replaced too with something better. I had both in my PC for a while but come to the conclusion that the Revo sounds better - more dynamic (this was before mod). Sold the 410 a while ago so cannot comment on the layout.
Deep down inside. |
#12 |
So one last try.
Before this got off topic, I haven't seen an alternative for under 200 bucks to the 410. Anybody want to chime in? I'll be ordering in the next couple of days so.... |
| M-Audio Delta-44 and instrumentation under Linux | suzyj | Digital Source | 8 | 27th July 2007 03:43 PM |
| Word Clock For M-Audio Delta 1010 | 300_baud | Digital Source | 0 | 19th August 2006 05:08 PM |
| Cal Audio Delta Transport Spindle Motor Help | dclu | Digital Source | 4 | 19th June 2006 06:19 PM |
| Ps Audio Delta 250 | diy guy | Solid State | 0 | 20th July 2004 09:29 AM |
| I2S tapping to M-audio Delta 44 | Kohjin Yamada | Digital Source | 0 | 9th July 2004 06:58 AM |
| Page generated in 0.07238 seconds (70.65% PHP - 29.35% MySQL) with 11 queries |
