| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi all,
I have had a CAL Gamma dac sitting on a shelf for about a year. Yesterday I hooked it up and found that the sound from my Parasound CDP 1000 player is better. What can I do to improve this unit?
Gavin |
#2 |
If you have not gotten rid of your Gamma DAC and you are handy with sodering gun, here are what I have done to substantially improve the sound of my Gamma DAC.
1. Replacing the pair of TL071 OPAMPs with OPA627s and conecting one 2.7K resistor between pin 4 and pin 6 of each OPA627. I have also tried OPA124, AD743 and AD829. I prefer the OPA627 by a large margin. 2. Replacing the pair of ouput capacitors and the pair of OPAMP decoupling capacitors with ELNA Cerafine 220uF 16V capacitors from http://www.welbornelabs.com/elna.htm . You may also condider Black Gate N type capacitors. They are the favorate of many advanced DIYers, though I do not have personal experience with them. I am quite happy with the sound of my Gamma DAC now. Hope you will try some modifications and have fun. BTW, I use a 6N1P SRPP tube pre amp and a DOZ class A FET power amp.
Tim King |
#3 |
hi guys, I know this is an "ancient" topic, but I am doing this upgrade on a Gamma which I had for free from a friend of mine, and I wonder about the reason why there are the two 2,7K resistors between pin4 and 6 of the OPA.
Can someone please explain that? I love music, but sadly I'm not so much into electronics... |
#4 |
Hi Pepolino:
2.7 kohm give the Opamps 4.4 ma of current at zero signal, allow it to run "kind of class A" amplification. The original OP627 is extremely accurate but sounded sterile. With the 2.7k it is much more musical. I apologize for the late answer. I do not browse the board often.
Tim King |
#5 |
Thanks, TTTKING
do you have also an idea about the reason why the volume is lowered now compared with the original OPA? It is not a small difference, it's really a very noticeable difference between the two! I have to rotate volume knob up to 3/4 to listen to same level that I was getting at 1/4 before! |
| Anyone tweaked a California Audio Labs Alpha DAC? | beau2317 | Tubes / Valves | 8 | 25th August 2010 04:23 AM |
| California Audio Labs vs Musical Fidelity | Charles Wasserf | Digital Source | 0 | 27th February 2009 08:06 AM |
| Another California Audio Labs CL-5 Question | neddyboy | Digital Source | 1 | 7th October 2007 12:06 PM |
| California Audio Labs Genesis | lpd | Digital Source | 0 | 22nd November 2006 10:36 PM |
| Schematic California Audio Labs Aria MK III??? | zabaltegi | Digital Source | 0 | 31st May 2005 08:50 AM |
| Page generated in 0.10151 seconds (72.09% PHP - 27.91% MySQL) with 10 queries |
