Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th June 2004, 05:46 AM   #1
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
Default Non-Oversampling dac & tweeters
I have found mixed opinions on the net regarding the possible negative influence (eg. kaboom) that the HF garbage (images) that non-os dacs produce might have on extended response tweeters that do not have a protective self-inductance.
I have a pair of Infinity RSII's (EMIT planar-magnetic tweeter - flat to 32kHz) which came from the factory with 1.5A fuses on the tweeters (paralelled, 2 ohms impedance).
edit: amplifier bandwith is DC-150kHz, -3dB
Should I worry about this?
some spectrum data:
http://www.diyparadiso.com/teksten/i.../solnodac1.htm
(not I'm going after but the non-os output should be similar)
Thanks!
Deep down inside.
Old 10th June 2004, 05:51 AM   #2
pburke is offline pburke  Germany
Magnepan 3.5R here, tweeter fuses removed, non-OS DAC, happy camper.
Old 11th June 2004, 11:29 AM   #3
So I guess everything would be ok. I'm looking for more opinions though...
Deep down inside.
Old 11th June 2004, 04:27 PM   #4
Werner is offline Werner  Europe
This is generally unproblematic, for two reasons.
First, the zero-order-hold nature of most NONOS DACs (exception: the TNT Convertus Decima, which was just an experiment) implies a treble rolloff following Sin(f)/f, which attenuates the HF output strongly above 35kHz, and even nulls it completely at 44.1kHz.
Secondly, the spectrum occupied by most music falls off drastically above 4kHz or so.
These two things combined mean that in the band 20-35kHz there is not a lot of energy (due to the nature of music), and in the band 35-50kHz there is not a lot again, due to the Sin(f)/f droop.
Remember that it is power that destructs tweeters, and even with a signal voltage attenuation of 10 dB (not that much), power is down to 10% of the original level.
Old 11th June 2004, 10:28 PM   #5
Thanks werner!
PS. I just put the tweeter fuses back in (sounds a bit with my current setup) and if everything goes ok I'll remove them after I finish building & testing the thingie.
Deep down inside.
Old 25th June 2004, 11:25 PM   #6
The DAC is up & running and no problem in two days with fuses on, I'll just remove them
Deep down inside.
Old 26th June 2004, 12:07 PM   #7
Bricolo is offline Bricolo  France
Bricolo's Avatar
AFAIK, this is untrue.
The sinc(f) rolloff exists in a non-os dac, agreed. But this is for the music reproduction. In other words, information stored in your cd, will have a slight treble rolloff when player through such a dac.
And, even more obvious: there's absolutely no music content on a CD, above 22kHz (Fs/s) so 35kHz and 44kHz sounds aren't attenuated, there aren't any! It's impossible to have them.
The 44.1kHz signal you have on the output of non-os dacs is due to the fact that your signal is sampled at 44.1kHz, so the dac sets a value on its output, maintain it for 1/44100 second, outputs a new value and keep it also for the same period, etc...
If you look closely at this output signal, it will be made of small steps
And those steps cause the 44.1kHz "garbage" on the output.
Decompose the signal in fourrier series, you'll see that the regularly spaced steps (at every 1/44100th of a second) will show an important signal at this frequency.
Old 26th June 2004, 12:37 PM   #8
Bricolo, you seem to be forgetting something. Without any filtering the entire 0Hz to 22k05Hz spectrum repeats every 44k1Hz.
Old 26th June 2004, 12:49 PM   #9
Bricolo's Avatar
could you explain?
Old 26th June 2004, 12:55 PM   #10
AFAIK, there is a lot you don't know.
what is 1x oversampling amp builder jb Digital Source 4 25th July 2005 02:38 PM
DAC- which way- oversampling or non-oversampling Rave Digital Source 24 20th March 2005 02:19 PM
TDA5141 oversampling or non-oversampling ? Bernhard Digital Source 4 1st September 2004 10:27 AM
Non Oversampling Vs Oversampling jkeny Digital Source 25 9th April 2002 07:50 AM
Page generated in 0.12059 seconds (87.45% PHP - 12.55% MySQL) with 10 queries
