Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
my own pga2310 pre-amp :)
Old 30th August 2004, 10:55 PM   #21
kafka is offline kafka  Poland
kafka's Avatar
I have a problem with shut down in OPA548. It works as -15V supply. I take 2.5V reference from TL431 and OPA inverts it with gain = 6. It works good. But I can't shut it down. I used the circut from the datasheet with dual supply mode. The e/s pin is at the same potentian as negative rail, so it should be good, but output voltage changes then from -15 to -12 and I can give quite a lot currnet.
And another question. How can I shut down reg1117(3,3V)? Any idea? I feed it from 5V regulator which is enable all the time.
Old 31st August 2004, 04:37 PM   #22
Devil_H@ck is offline Devil_H@ck  Belgium
Devil_H@ck's Avatar
Send a message via ICQ to Devil_H@ck Send a message via AIM to Devil_H@ck Send a message via MSN to Devil_H@ck
You could use a MOSFET to cut the power to the REG1117.
Normally the E/S pin on the OPA548 should allow you to disable it.
Website: http://members.lycos.nl/anthonyvh
Old 31st August 2004, 06:02 PM   #23
kafka's Avatar
I know it should, but it don't. The rest of OPA548 works well, but they have negative rail tight GND and I can drive them from TTL levels. That one have positive rail at GND level and negative at -18V.
my own pga2310 pre-amp :)Hide this!Advertise here!
PGA2310 & NE5532 get hot? sergiusz Digital Source 10 20th December 2005 01:32 PM
PGA2310 v PGA4311 daArry Digital Source 1 12th April 2005 08:52 AM
pga2310 in parallel ? blu_line Solid State 3 18th August 2004 09:22 AM
Control of PGA2310 nowater Digital Source 1 22nd January 2004 03:43 AM
CPLD vs. uC for PGA2310 ajm8372 Solid State 6 20th January 2004 11:40 PM
