| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have already started a thread in tubes section that has as purpose finding a way to simulate the "special coloured" "tube sound".There you're all invited to give some information and ask for too, about what tubes do with the signal and how this affects the listener's perception.
This thread is meant to be a brother of that. Here you can too to post anything that can be done with DSP. There we already mentioned some of those things, so I'm asking you all who want to post, first do a scan there to have an ideea. Thankyou all and respect.
...it can be better |
#2 |
I find it amusing that it takes a DSP chip with half a million transistors to try and emulate technology 80 years old. Besides, theres no fun in watching a DSP chip.
#3 |
You've already got it wrong here. Sorry to say that but isn't this a little to arrogant to start with?
Yes is seems like with a n-milon transistors DSP circuit could approach tube's effects. But could would you emulate at same quality, simplicity, size and efficiency a DSP circuit with tubes instead of transistors? Wich way is better in your opinion? And another thing, with all the respect (I'm yunger than you) please, be compliant and make a concrete point, we're not discussing here witch can be better we're trying to make both better. Chating about tubes and emulating their effects is a good thing because it needs that those effects to be describled and may help some ppl understand them better. If you're not interessed you may find other things on this forum, or you coud put your critical ideeas in another light.
#4 | |
However for many other type of tube amps it is debatable if they colour sound or not compared to SS amps, there are many indications of the opposite, for instance it seems that only the very best SS amps give a sound quality as a reasonably good tube amp, this points to that tube amps give less colouration and not more. For other than HIFI applications there have already been amps designed using SS technique that try to simulate tube sound, if I remember correctly Marshall or some other guitar amplifier manufacturer is selling this already using DSP technique but in this case I think the goal is to mimic the clipping behavior including the sag of a tube rectifier in the power supply. Regards Hans |
#5 | |
You got the ideea?
#6 | ||
Regards Hans |
#7 |
Yes it should be possible in theory to emulate the sound of a tube amp with signal processing. As to how someone would go about doing that is beyond my skill level. Its documented that tubes produce even order distortion where silicon produces odd order. The sound of even order is described as warmer and less harsh. Maybe theres an SDK or something available for programming DSPs on high end sound cards?
#8 | |
Here's the link for the drivers (they also run with any sound card that has EMU processor: Audigy series of cards, and E-mu Systems' Audio Production Studio sound-card): http://kxproject.lugosoft.com/index.php?skip=1 That's their main page if anyone interessed.
#9 |
i think to get this past the point it's already been discussed to, go and read this, the original posting (at the moment it seems like the same old stuffs being repeated here again).
DigitalSignalProcessing -> future? |
#10 |
Every circuit has a transfer function. Even a simple wire. These transfer functions can be measured. So, measure the transfer function of whatever tube amplifier you wish to emulate, and your transistor based DAC/amp. Subtract the two. That should yield a transfer function which will make your DAC/amp sound like the tube amp. Implementing a convolution by transfer function in a DSP is about the most basic thing you can do in a DSP. The code should be readily available.
| DigitalSignalProcessing -> future? | Polimorph | Tubes / Valves | 40 | 10th June 2004 07:08 PM |
| Page generated in 0.11968 seconds (82.82% PHP - 17.18% MySQL) with 10 queries |
