Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th June 2004, 07:24 PM   #1
Send a message via AIM to dunderchief
Default 4 Way PC crossover project
Hi there guys.
I've read through every software crossover thread on the site, and while I've learned more than needed I can't seem to get all my eggs in one basket. I thought if I put everything down at once I might be able to get a definitive answer. So here's what I need.
I need a 4 way stereo software crossover for the Windows environment. I know BruteFIR is the obvious choice here, but for reasons yet to be disclosed I need to stick with windows.
AsioXO is capable of 3 way crossovers, but I need 4 way. Is there some way to fix this?
DRC with windows is already taken care of so I don't think I need to worry about that.
Sound card will likely be a Delta 410 from M-audio, but I was also going to ask if there are alternatives that may yield better results in the same price bracket.
An easy interface is always nice, but not necessary.
I'm sure there was more to ask, so I will add when I think of it.
Thanks in advance
-Steve
Old 9th June 2004, 07:33 AM   #2
Okay, so I got no response. Kind of figured that would happen. So I'll make this a little easier and more direct.
Is it possible to obtain the same capabilities of say a Behringer DSP unit, or the driverack, or any of the other prosound DSP's using a M-audio Delta 410 and Sounds Logical Wave Warp? So far this is the only program that I've found that seems to have the capabilities I need in the windows environment.
Old 17th June 2004, 05:40 AM   #3
One more try folks.
Is there anything in the windows environment that will allow me to do a 4 way active crossover. FIR or IIR, I don't really care. Just something.
Old 17th June 2004, 05:51 AM   #4
blu_line's Avatar
Program an IIR yourself !
There are lot of programs which can calculate coefficients for you.
WAV files are quite easy to disassemble.
grtz
Simon
Old 17th June 2004, 06:46 AM   #5
I know that it would be easy to just build the coefficients, but the process needs to be streamlined, easy, and pretty, not to mention ready to use by the end of July. I think Wave Warp will do it, but nobody seems to have used it.
First (Noob) crossover project - upgrade klipsch RF-7 okapi Multi-Way 32 1st August 2011 08:12 PM
3 Way Active Crossover Design project powagrip Multi-Way 13 23rd February 2005 08:06 PM
active crossover project victordsouza Multi-Way 0 9th September 2003 04:17 PM
New crossover project? mikewu99 Multi-Way 3 27th January 2003 07:08 PM
Page generated in 0.07262 seconds (80.75% PHP - 19.25% MySQL) with 10 queries
