| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 | |
Banned
You need to explain a little bit more for us to understand... 1. Only one battery? 2. How do you create that virtual ground? 3. The GND of the dac is connected to V- on the battery, where is the + of the Dac connected to? (this question may seam stupid, but I'm trying to understand how many batteries do you have and how you connected them).
#12 |
Do I understand correctly that this resistor is generally used to avoid the pops & therefore does not affect sound quality?
TIA |
#13 |
Banned
if it sucessfully prefends from pops, what it will do if it looks like a resistor to the electrons sitting on the cap, and is connected to ground, it will affect sound quality in so far the pops are gone. This may be a worse sound degradation, as a pop is sound and no pop is obviosly less sound than one.
If you want improve the sound further, you will find loads of ways how on this board, one is laying a stone as near to the cap as possible. There is nothing bad on those resistors, but it may be a bad experience to connect a charged cap to the input of a cranked up hifi system. |
#14 | |
The power supply is series pack of 8x1.2v nimh cells. The virtual ground for the amp is created using a 3 terminal monolithic device from TI, the TLE2426. The Dac is fed from the +- terminals of the battery pack and the voltage regulated according to component needs.[8v,5v] Cheers Setmenu |
| Fs Tda1543 | stonehome | Swap Meet | 1 | 13th February 2008 04:28 PM |
| DAC: TDA1541 and TDA1543 question | morpheus82 | Digital Source | 44 | 17th August 2006 12:37 AM |
| Question regarding discrete I/V converters [ for TDA1543] | setmenu | Digital Source | 0 | 3rd September 2004 03:03 PM |
| Nos Tda1543 Dac. | IpsilonSound | Digital Source | 0 | 4th June 2004 06:25 PM |
| Where to buy tda1543 | RAYSIMMONS | Parts | 1 | 17th May 2004 04:03 AM |
