Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd June 2004, 10:22 AM   #11
Bricolo is offline Bricolo  France
Bricolo's Avatar
ok I'll try this
I have some AD8065, are they OK for this use?a
Old 2nd June 2004, 10:55 AM   #12
banana is offline banana  Hong Kong
Guido,
About the Opamp approah. Do I need to add bias to the SPDIF signal before feeding it to the Opamp? I mean offsetting the "bipolar" +0.25/-0.25V input signal into "single-ended" +2.75/+2.25V, before amplification.
Or should I run the Opamp with +5V single supply and simply clip the output to +5/0V?
Old 2nd June 2004, 11:39 AM   #13
Originally posted by banana
Guido,
Hi
Yes, need bias at half of supply voltage
NEVER clip digital signal;s at such important places
regards
Guido Tent
www.Tentlabs.com
Old 2nd June 2004, 12:01 PM   #14
Banned
Guido,
Is the LM6171 a good choice for that job?
Old 22nd June 2004, 09:23 PM   #15
Originally posted by carlosfm
Guido,
Hi Carlos
should work well - no clue on the sound (all you do there is audible, subtle but audible :-)
regards
Guido Tent
www.Tentlabs.com
Old 23rd June 2004, 05:18 PM   #16
Default S/PDIF Input
You can't use most op-amps because the signal is in the 6 MHz range. If the lvel is too high coming from your source, you can attenuate it with a resistor. However, I use a 74AC04 operating on a 3.3V supply to buffer the input on my unit. You don't need anything fancier. On the electrical input, I couple the S/PDIF signal through a DC blocking capacitor to the input of the 74AC04 through a 220 ohm resistor. The input is biased with two resistors to 40% of the supply voltage.
On my opto input, the output of the TORX141 is buffered through another section of the 74AC04.
Dan Fraser
Old 23rd June 2004, 05:57 PM   #17
A little sharing, though most of you might already know. TTL gate does not work in the case of U3 on DEM-DIR1701 instruction manual. The first gate is actually a linear amplifier and only CMOS gates are suitable for doing this.
Before I learned this, I tried 74F04 and 74LS04. No matter how I bias the input DC, these TTL gates won't have symmetric output duty cycle. And they don't amplify, instead they simply switch on or off.
Finally, I settle on ADM1485. It's plug and play, trouble free. Thanks Andrei.
Convert Line Level to Electric Guitar Level miallen Solid State 4 16th May 2010 01:22 PM
How can I convert SPDIF to EFM (RF) signal, to use a cd player as a DAC ? gaetan8888 Digital Line Level 10 8th February 2009 07:32 AM
DIY 24bit Mic level A/D -> SPDIF out? scott wurcer Digital Source 1 14th May 2007 09:15 AM
which is a better spdif-to-cmos converter? rlim Digital Source 4 15th June 2004 07:03 AM
Want to convert amplifier output to input level rkc7 Everything Else 1 16th May 2004 10:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
