Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
TDA1543 resistor i/v
Old 31st May 2004, 01:28 PM   #1
till is offline till
Banned
Default TDA1543 resistor i/v
experiment
sounds realy bad:
Old 31st May 2004, 01:30 PM   #2
Banned
sound better :
Old 31st May 2004, 01:46 PM   #3
Bricolo is offline Bricolo  France
Bricolo's Avatar
you have to put something between vref and gnd
http://jwg.student.utwente.nl/fedde/images/nonoz3.gif
Old 31st May 2004, 02:02 PM   #4
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Hereby a pdf of what's been discussed to death. It was explained excellent by Rbroer:
It's only audio. Member of the non modular PCB design committee
Old 31st May 2004, 02:49 PM   #5
Banned
"you have to put something between vref and gnd"
my datasheet say " R bias - optional " what should mean i dont need it it the shown config.
Old 31st May 2004, 03:00 PM   #6
Bricolo's Avatar
I think it's optionnal with an opamp IV, not with a passive IV
Old 31st May 2004, 03:55 PM   #7
carlosfm is offline carlosfm  Portugal
Banned
till, with passive I/V, it's very critical the value you use between Ref and ground.
You have to use a resistor there.
I always use a 2.2k trimmer and it's so critical that you can tune it by ear.
Sound goes away, hiss, comes back distorted and finally clear (in both directions this happens).
There's a sweet spot thats not wide.
In the end you can measure the trimmer and put a resistor of that value there.
Unfortunately, the position where it sounds best is not the one with lower DC.
Old 31st May 2004, 04:11 PM   #8
Bricolo's Avatar
but there's no advantage in having a low DC, since you have a cap at the output
Old 31st May 2004, 04:13 PM   #9
Banned
Of course.
Better with no cap, but not here.
Old 31st May 2004, 10:55 PM   #10
Banned
I did the trimmer at Vref some time ago, and i ended up with very low resistance there.
The reason for this attempt was i wanted without the resistor, and i´m sure it will work without. (datasheet)
Following the information in posting above and the datasheet i would need to set the voltage with the divider to about 2,3V, and use 650R/760R resistors.
TDA1543 resistor i/vHide this!Advertise here!
12x TDA1543 at 6V, output and Vref Resistor values mudihan Digital Line Level 9 23rd March 2011 09:33 PM
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
TDA1543 DAC with resistor I/V and tube amp wa2ise Digital Source 4 19th September 2005 02:53 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
TDA1543 dac Rotellian Digital Source 9 12th September 2003 08:38 PM
Copyright ©1999-2017 diyAudio
