Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th June 2004, 08:26 AM   #31
A 8 is offline A 8  Sweden
Now it gets interesting, this is the Sony CDP playing a -70dB Dithered 16/44.
Old 5th June 2004, 08:28 AM   #32
Compared to the DAC Tester with no dithering at -70dB 16/44
Old 5th June 2004, 08:29 AM   #33
Last out is the dactester @-60dB 24 bits and 44kHz
Old 5th June 2004, 05:08 PM   #34
Pedja is offline Pedja  Serbia
A 8, if that may help, you can download both dithered and undithered, 0dB and -60dB sine signals (.wav files) from here and burn by yourself to CD. You have there all the files analyses as such, so you can know what you are working with.
Pedja
Old 5th June 2004, 07:16 PM   #35
Bernhard's Avatar
Could it be that compared to the -70dB signal, with -60dB there are more bitd switching in the DAC chip and those extra switching bits are bad by accidant in the Sony ?
Old 6th June 2004, 09:43 AM   #36
Thx Pedja,
I tried to burn these files but the program states they are the wrong format!?
Any idea as to why I can not burn them?
Also, looking at your pics I see similar hash on the non dithered signals.
Could it be that the "hash" only shows when analyzing 16 bit non-dithered data on a 24 bit processing system?
Old 6th June 2004, 03:38 PM   #37
I did not encounter any problem. What program do you use to burn them?
That hash is the regular part of the conventionally generated signal. That’s why dither. The difference can be seen normally on 16 bit system.
Pedja
Old 6th June 2004, 03:51 PM   #38
Its a HP burner and I use whatever came with it; HP CD writer powered by veritas.
I've checked the files on my Xp laptop and they are indeed 16/44 but only one channel...perhaps thats why.
Old 6th June 2004, 04:20 PM   #39
Yes, these are the mono files. Work normally with Nero so I did not expect it can be the problem. The brief check says EAC or even Windows Media Player 8 (XP) can burn them too.
Old 6th June 2004, 06:27 PM   #40
Pedja,
I downloaded NERO and it worked...also seems the data source makes a difference.
OJG,
The pic below shows the passive balanced PCM1704K @ 0dB and a analog attenuator before the soundcard....still looks better then expected.
Any traditional jazz fans out there? Bill Fitzpatrick Music 32 25th August 2008 07:15 AM
Listening axis for traditional speaker gainphile Multi-Way 6 19th May 2008 09:14 AM
Regulated vs. Traditional roibm Power Supplies 13 20th November 2004 04:09 PM
Non-traditional switching supply Kilowatt Solid State 10 20th January 2002 10:06 PM
Page generated in 0.11094 seconds (79.02% PHP - 20.98% MySQL) with 11 queries
