| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
HI,
does it make sense to filter the ground with a ferrite bead or large value inductor ? Also how about a floating ground ? Opamp ? Voltage regulator ? That could be heavily filtered before the "ground regulator". Bernhard |
#2 |
If you place a bead on the ground...
Imagine there's a current spike (like ezverything switches on), it's a transiant, but it's normal Here, your choke will filter this, and will "lift" the ground potential. But only the ground of the 7220. If this phenomen is big enough, a 0 at the output could even be ween ad a 1 for other devices connected to the normal ground |
#3 |
diyAudio Moderator Emeritus
Spot on !
It's only audio |
#4 |
Not with a big cap across supply pins ?
#5 | |
As well, as I/O currents are also ground related You could however decouple all I/O but will end up with something that wont function at all What is the rationale behind wanting to add a ferrite inductor ? You probably have read to many reccommmendations from AD. TI, BB and Crystal forget about them, please......... regards |
#6 | |
Banned
#7 | |
#8 |
Banned
How did you come up with that idea.............?
Never mind.....I'm not that curious. Jocko |
| Dac clock harmonics filtering ? | gaetan8888 | Digital Source | 1 | 7th September 2007 08:01 PM |
| clock (bck) buffer SAA7220 | Jaman | Digital Source | 4 | 7th July 2007 05:33 PM |
| Saa7220 sparks from ground pin (killed a saa7220 ?) | ash_dac | Digital Source | 26 | 26th March 2006 02:32 PM |
| SP/DIF out of SAA7220 | Sandor | Digital Source | 16 | 6th February 2006 03:38 PM |
| does connecting mains ground with circuit ground create a ground loop? | jarthel | Everything Else | 0 | 25th June 2003 12:55 PM |
| Page generated in 0.09114 seconds (77.44% PHP - 22.56% MySQL) with 10 queries |
