| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I just saw this amp mentioned on another forum and decided that for $30 I have to have one. Thought it might be of interest even though not DIY.
http://www.target.com/gp/detail.html...sin=B00009W44B http://www.si-5.com/newproducts.html Im going to re-chassis it if it sounds good using binding posts and proper RCA jacks etc. Oh and the PS is optional (wallwart) if you dont want to use batteries. amt |
#2 |
Sounds like there is a Tripath TA1101B working in the amp.
It delivers 15W per channel class-T. In germany you can get it as a kit for 30 and finished up for 70. Iīd say itīs a really good deal for what itīs worth and probably would make a nice little PC amplifier. |
#3 |
the site says the amp uses TA2024 class T amp chip.
#4 |
I wonder if i would be able to find one in Australia?
Seems Interesting? Make sure you post some info about it wen you get it and maybe some pics.
"The 15 year old wonderchild in audio" |
#5 |
Iīd say itīs a really good deal for what itīs worth and probably would make a nice little PC amplifier. [/B][/QUOTE] ---------------------------------------------------------------------------------- Can you post url for web buying in Germany. Can't get it from the US (no overseas posting) |
#6 |
I picked up a couple of these to play with. Haven't done much with them yet though. I'd suggest running them from a 12V SLA battery - it will provide much better performance than either a wall-wart or a set of alkiline cells. A 7Ah battery plus charger will run probably $25 or so, so it won't break the bank.
The entire amp is a single small PCB, so moving it to a new chassis won't be much of a challenge. Given the cheapo connectors on the stock unit and complete lack of shielding (plastic case) it has the potential to make some noticable improvements. BTW - the 15W rating is highly optimistic. Figure more like 8-10W of clean power. |
#7 | |
seen this one really late... Hereīs the amplifier-link. Thatīs the building-plan + schematic as pdf-file. http://www.elv-downloads.de/service/...erker-T-30.pdf (If you have any questions about the german text you can drop me a mail.) You can also just buy the PCB if you want.: http://www.elv.de/Main.asp?Menue=Sho...25890478862941 Mmmh, links (except pdf) donīt work. In that case go ELV and search for "class-t" First thing that comes up is the 300W-version, then the the single PCB (T30) and finally the kit or finished T30.
jens |
#8 |
Bought one of these a while ago-there is a picture of the insides in the zipped folder below. A pretty good sounding amp,but not as good as my gainclone.The only thing I didn't like about it is that it produces quite a bit of hiss through the speakers,even with batteries.
| Progress report - digital crossover as a DAC - digital all the way to the amps | Ken L | Multi-Way | 0 | 27th November 2006 12:42 AM |
| digital crossover w/digital output? | ezkcdude | Multi-Way | 30 | 3rd August 2006 02:01 AM |
| Get digital signal from an old CD-Rom without digital output | genome | Digital Source | 5 | 4th February 2004 12:54 AM |
| Page generated in 0.11014 seconds (74.97% PHP - 25.03% MySQL) with 11 queries |
