Source for SAA7220 and SAA7210 - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd May 2004, 08:41 PM   #11
Default SAA7210 and SAA 7220
I'll try that tomorrow and see what happens. I'll probably desolder the pin on the 7220 and jumper the clock to the 7210. I know that the 7220 supplies the clock to the7210 and the 7210 sends it back to the filter, so I gues we'll see.
PH
Old 24th May 2004, 08:38 PM   #12
Default disk spins problem
No luck on the bypass to the 7210 for the clock. Disk still spins at max speed. I replaced the 7210 and that didn't fix it either. With no schematics for the Rotel 855, progress on this is likely to be slow. All power supply rails appear to be working as advertised, as I took some measurements from a friends machine. Unfortunately I couldn't tear into it far enough to check the transistors and op amps under the transport...
Sugestions?
PH
Old 25th May 2004, 09:23 PM   #13
TDA1540 is offline TDA1540  Netherlands
TDA1540's Avatar
I think you should check the supply around the killcircuit.
If something is amiss,it affects the processer(assuming the Rotel PCB is actually a Philipsdesign)
Have had some Philipsplayers on my table where the owners had messed with the killcircuit(mutingtransistors).They showed similar symptoms.(the players.....not the owners)
TDA
Saa7220 sparks from ground pin (killed a saa7220 ?) ash_dac Digital Source 26 26th March 2006 02:32 PM
SP/DIF out of SAA7220 Sandor Digital Source 16 6th February 2006 03:38 PM
overclocking SAA7220 ? Bernhard Digital Source 4 7th February 2005 12:04 AM
Shematics needed for brand new SAA7210+SAA7220+TDA154... stand-alone nonos dac iklari14 Digital Source 2 14th August 2003 10:15 AM
Copyright 1999-2017 diyAudio
