Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th May 2004, 09:03 PM   #1
akku is offline akku  Italy
Default tda1311 and clock question
I was thinking of putting a new clock in my CDP with tube output stage so (missing a service manual) I opened it and I found a TDA1311 D/A converter. On the datasheet it seems somethig like the 1545 but with voltage output and worst specs on THD.
Some questions:
1) Anybody heard about this chip? Is it a good one or is better to forget about modding the CDP and look for something else?
2) On the board I have found two crystals: one 12.000 and one 16.9344. I guess the latter is the one to substitute with a clock board (maybe KC7). Am I wrong?
Many thanks to everybody.
Old 19th May 2004, 08:44 AM   #2
Default Re: tda1311 and clock question
Some questions:
Hi
1 - I have no experience with the 1311
2 - The 16.9344 MHz is the conversion clock
succes
Guido Tent
www.Tentlabs.com
Old 19th May 2004, 01:31 PM   #3
Hi Guido,
thanks for your reply.
16.9 makes sense, the decoder is SAA7345.
I read on your website that the clock wiring have to be kept really short. I can't put the clock board near the original quartz because is placed under the drive mech.
What's the length of the wiring you supply with your board?
Anybody had experience with 1311?
Old 19th May 2004, 05:05 PM   #4
Hi Guido,
Hi
I'd suggest 10 cm, the twisted wiring works fine
If you use coax it can be longer, assumed it is terminated at the other (receiving) end
regards
Guido Tent
www.Tentlabs.com
clock question? tomat Digital Line Level 9 28th October 2009 07:24 PM
ezDAC clock question M-chen Digital Source 2 7th February 2009 05:52 PM
Fitting clock question D.A.R.R.Y.L. Digital Source 6 24th February 2007 11:22 AM
Probably easy clock question Tor M Digital Source 10 2nd June 2004 08:32 AM
Page generated in 0.08638 seconds (74.27% PHP - 25.73% MySQL) with 10 queries
