| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi...
Could a digi head with more know-how then a newb tryin to wing it (which would be me ;p) please run they're eyes over this PDF schem for an adc: Bal/UnBal PCM1804 ADC Any feedback appreciated ![]() Ta |
#2 |
It seems a bit wasteful. The input takes a balanced signal which is then converted to unbalanced (IC3a IC3b), it is attenuated and then two more op-amps are used to convert it back to a balanced signal to feed into the ADC.
Why not use a PCM1802, which is the same ADC chip which accepts a single-ended input, thus elimintaing the need for two op-amps in the signal path? Adrian |
#3 |
Because I wanted the option to take both bal and un bal inputs - not just unbalanced only. The 1804 also seems to have better specs then the 1802. Electronically, does everything look okay to yas tho?
Cheers |
#4 |
Okay, howzabout this then version then? It uses the OPA1632 (I pretty much followed the application schem in the opa datasheet and filled in the blanks by way of the PCM1804 eval brd schems...
Schematic PDF PCB Layout PDF Cheers. NOTE: The unbal header is for a switch - which when pressed flips the inverting input to gnd for single ended input. |
#5 |
Sorry to dig out this old thread, but did you (meta) or anyone else ever try this ADC?
/U. |
#6 |
Hey Nisbeth...
Nope, never tried this circuit in the realworld yet - gettin some DACs done 1st is a higher priority atm ![]() Best. |
#7 |
I am considering giving it a go. Will you share you pcb layout and parts list (if you have it)?
TIA! /U. |
#8 |
do u want the layout as a pdf or open eagle files u can edit/print urself?
#9 |
A pdf please
You can post it here or email it to uffe(at)nisbeth.dkThanks! /U. EDIT: But someone else might like the eagle files...? |
#10 |
HERE is a zip containing the top overlay (showing the 3 bridges too), bottom and schem (use that for a parts guide?). I've added the LED overflow circuit too (based on the layout on the ti 1804 eval brd)...
Keep u posted
| OPA1632 + PCM1804 question | dismirlian | Digital Source | 2 | 4th July 2007 04:40 PM |
| PCM1804 acting up | MC | Digital Source | 6 | 6th April 2005 05:54 AM |
| Bal-Unbal-Bal Cable Wiring | richie00boy | Everything Else | 3 | 3rd February 2005 11:08 AM |
| New TI chip unbal to bal | markp | Solid State | 9 | 25th January 2005 08:16 PM |
| PCM1804 -> TAS5015, Analog PWM amp | fr0st | Digital Source | 0 | 26th August 2003 12:59 PM |
| Page generated in 0.09479 seconds (78.02% PHP - 21.98% MySQL) with 10 queries |
