'Proper' clock divider - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th May 2002, 06:40 PM   #11
tiroth is offline tiroth  United States
Sorry for not thinking that through, I realize why latching is necessary.
Old 18th May 2002, 07:55 PM   #12
Here is the current iteration of this circuit. The buffer is included so that the rise time of the distributed clock is slower and to ensure Tlh=Thl. A 74HC241 will be used; the LS part is simply for simulation. Any criticism on this setup?
The timing is actually a little tight for worst-case, but I think the 74F logic will be quite sufficient. Looking at the timing diagrams more closely, the latch could probably be omitted, but I think this would open you up to a host of potential timing issues.
Old 18th May 2002, 07:56 PM   #13
Timing diagram for above. LRCK rises on the falling edge of BCK, as intended. I haven't found any datasheets that require a specific phase relationship between MCK and BCK/LRCK, so I believe this could be a good general purpose clock divider.
Old 21st May 2002, 01:15 PM   #14
ftorres's Avatar
Looks good to me, but I trust you for the different connections . Just don't forget to ground unused inputs on the 373. Speaking of that, did you have particular reason for chosing a 373 (level triggered) instead of a 374 (edge triggered) ?
François
"Learning French is trivial: the word for horse is cheval, and everything else follows in the same way."
Old 21st May 2002, 02:52 PM   #15
ftorres's Avatar
tiroth, can you give me your mail address ? (I can't help sending you a message from your web site....)
François
Old 24th May 2002, 01:46 AM   #16
ftorres recently informed me via email that an 8 bit syncronous counter does in fact exist, the 74F269. This would be superior to the discrete solution.
Precision Voltage Divider - diy redrabbit Equipment & Tools 3 24th July 2008 04:16 PM
Reg and Pass V Potential Divider iUSERTLO72p Power Supplies 7 17th February 2008 10:00 AM
voltage divider+Aikido anawat Tubes / Valves 0 17th October 2007 05:19 PM
Variovented divider panel + more ro9397 Subwoofers 12 16th October 2007 07:39 PM
PGA2311 or resistor divider? fmak Parts 2 3rd May 2004 02:34 PM
Copyright ©1999-2017 diyAudio
