Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Rotel cd player
Rotel cd player
Old 26th September 2003, 08:09 PM   #21
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Originally posted by jean-paul
Most of the time the same discussion applies to TDA1541A and TDA1541A-S1. Some hear a difference while others claim to hear no difference at all. I was surprised by Peter Daniels report on the difference a S2 version makes.
http://www.diyaudio.com/forums/showt...hlight=tda1541
I'm very surprised too...would think A to A-S1 would be a bigger improvement than A-S1 to A-S2.
Anybody bought one of those S2's from Elib and would let me borrow and test-drive one ? Got a socket for the TDA1541, so it would be plug and play.
Maybe Thijs ?
Rudolf Broertjes
Old 13th October 2004, 01:40 AM   #22
dom letor is offline dom letor  United States
Send a message via AIM to dom letor
Default PCM-63-K piggyback?
hi,
just wondering what exactly does "piggyback" mean, and why would you want to do it to a DAC chip? is it any good?
dan
Old 13th October 2004, 02:36 PM   #23
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Piggybacking is soldering 2 of the same chiptype on top of eachother. Some say it sounds somewhat better, I think it is a waste of money, materials and energy.
It's only audio. Member of the non modular PCB design committee
Old 14th October 2004, 05:48 AM   #24
Fin is offline Fin
Fin's Avatar
My experience with replacing PCM63P or J is slightly different. K version is an improvement ( not too big but remarkable ).
Last time I bought K versions they were so cheap that I replaced the old ones for them anyhow.
Hi Jean-Paul
Where did you buy the PCM63P-K at a good price?
I assume these would be a good match with SM5842APT?
Fin
Old 15th October 2004, 07:01 AM   #25
kolwrath is offline kolwrath  Canada
Lightbulb Some mod ideas
Hey,
I have an old Rotel 965BX that I moded. Here's what I did (may give you some ideas)
1. Replaced the OpAmps (OPA627)
2. New clock: trichord clock2's (its only about ~$44 pounds, way cheaper than any aftermarket clock I have seen)
3. New insulating feet
4. Removed the mutting transistors (cheep $0, really easy, and effective)
5. soon to be done: new female rca jacks and silver hookup wire.
6. soon to be done: new EMI filter IEC power plug, and a decent power cord
All pretty simple ones. Only the new clock was reall expensive.
Advanced ideas:
1. Replace capacitors (blackgates)
2. replace powersupply
3. replace rectifiers
4. insulate chasis with dampeners, and or lead/copper shielding
Good luck.
Old 15th October 2004, 03:07 PM   #26
buchignani is offline buchignani  Canada
Default 971 mods
I fiddled quite a lot with one of these, and eventually I liked the sound as much as my Meriidian 508-24 (although it sounds very different).
replaced the main std rectifier diodes with 100V Schottkys, 8TQ100, Internation Recifier
replaced the audio output OpAmps with LM6172 (two of them)
installed an LC Audio replacement clock
added about 300uF extra low Z capacitance to the +- OpAmp lines
replaced the 100uF output caps with 15uF poly Auricaps.
bypassed most (about 12) power supply caps with ceramic 1uF
added 1uF ceramic bypass to the +-V supplies to the output OpAmps (which were already bypassed by .1uF film and 10nF film).
added a 10pF feedback cap to the LM6172s as per the spec. sheet
added a snubber network across each side of the transformer
secondary: a 100 ohm resistor and a 0.47 uf film cap
replaced main digital power supply cap with 8,800uF low Z cap
Old 22nd October 2004, 06:23 AM   #27
Default advice for modding
i've been thinking about doing that mod. i've been successful with swapping out the op-amps with AD825s and installed a LCAudio X02 clock with separate power supply. my CD player is the Rotel RCD-971.
i'm still a newbie modder though, cuz i still have to ask: where do i find the diodes on my board? are they sticking out or are they the tiny round flat ones closer to the transformer? (how would i know if i had Schottkys already?) also, how do i tell which size and rating to get in order to prevent burning out the other components? if i know how to change the diodes then i'll be able to mod other stuff that i own.
another quick question... is there any benefit in changing the voltage regulators in audio equipment, or is it just not worth it?
thanks,
dan
Old 21st June 2009, 08:26 PM   #28
Iliya is offline Iliya  Russian Federation
[B]My experience with replacing PCM63P or J is slightly different. K version is an improvement ( not too big but remarkable ) but if there are adjustment pots on the PCB it is better to remove them if you haven't the equipment to adjust them for least distortion. Leaving them as they are will degrade performance of K or whatever version more than no pot at all. My experience with these chips was not when used in this particular Rotel cdplayer but in some Pioneer models and separate DAC's.
In my Rotel RCD-971 those pins for adjustment are not connected to anything. But the PCM63 datasheet recommends connecting the pins 23 and 24 to the ground via 0.1uF caps. I am planning to solder two Black Gate NX Hi-Q 0.1uf/50V for each DAC on the bottom of PCB as shown on the picture. Is that a good idea, any thoughts?
Rotel cd playerHide this!Advertise here!
Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player Staykov Digital Source 9 1st March 2016 10:40 AM
Looking for Schematic for Rotel RCD-975 CD Player dtm1962 Digital Source 1 19th February 2008 01:14 AM
Rotel or Jolida CD player ??? REALFLEO Digital Source 0 10th December 2007 01:35 PM
Looking for a Schematic for a Rotel RCD-971 CD Player dtm1962 Digital Source 3 27th July 2006 03:50 AM
Output Cap in Rotel CD Player wtyamamoto Digital Source 10 21st April 2006 01:51 AM
