Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th May 2004, 06:34 PM   #1
A 8 is offline A 8  Sweden
Default Passive I/V, poweramp, distorsion & SpectraLab
Until recently I have not been able to measure anything but ohms and voltage but in a recent thread I found a reference to SpectraLab and their FFT spectral analyses software and could not resist putting it on one of my laptops (IBM ThinkPad T21)
Now, I have always preferred passive I/V for completly subjective sonic reasons inspite my understanding that the overall THD will be much higher then a traditional opamp I/V.
However looking at the SpectraLab plot which is actually taken at the poweramp speaker terminals I seem to be doing pretty good considering.
I am a bit confused though, taking the THD reading of 0,01244% and converting to dB gives me -78dB THD which does not align with the graph, the graph shows a max around -95dB with most of the crap at around -100dB...?
Anyone care to comment and help me make sense out of it?
/Michael
Old 12th May 2004, 06:46 PM   #2
Andypairo's Avatar
The -9x dB level on the graph is a power spectral density (and it depends on the frequency resolution aka bin width IIRC), while the SNR is a ratio between two power levels.. that's why they are different.
Integrating the PSD over the 20-20kHz band should give you the right result.
Cheers
Andrea
Old 12th May 2004, 06:48 PM   #3
I'd also like to get a copy of the SpectraLab, could you pm me a link pls?
Old 12th May 2004, 07:10 PM   #4
Thanks Andrea, makes perfect sense. I tried to hit 0dB but my volume setting pushed the input stage on the laptop into clipping.
I am still a bit confused as to why it looks as good as it does considering my use of the laptops original soundcard and the passive I/V?
The link...http://www.pmgrp.com/prod01.htm#SpectraLAB
distorsion Q_tube Tubes / Valves 4 27th May 2005 07:09 AM
distorsion and generator tuben Equipment & Tools 0 2nd August 2004 06:53 AM
TDA1543 test results using SpectraLab. IpsilonSound Digital Source 28 23rd June 2004 10:59 PM
passive preamp for quadII poweramp renjiish Tubes / Valves 10 16th October 2003 12:15 AM
Aleph30 distorsion Koy Pass Labs 11 22nd July 2002 11:01 AM
Page generated in 0.08327 seconds (72.40% PHP - 27.60% MySQL) with 11 queries
