Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th May 2004, 03:02 PM   #1
pro is offline pro  Italy
pro's Avatar
Default Pass D1 output stage.
Some one knows if it is possible to apply the output stage of the Pass D1 to a CD player that it uses 4 BB pcm1702 in place of the BB pcm63?
The only difference between two me seems to be the output current that is 1,2 mA in place of 2 mA.
Thanks.
Old 18th May 2004, 10:21 AM   #2
Banned
i would expect it works, as it works also with AD1865
http://www.diyaudio.com/forums/showt...625#post383625
Old 18th May 2004, 01:08 PM   #3
CheffDeGaar's Avatar
Just scale R27 and R34 from original schematic to give you the wanted I/V conversion ratio :
2mA in 1K5 give you 3V FS, so use 2K5 for R27 & R34...
/Cheff - Falling feels like flying, until you hit the ground
Old 18th May 2004, 01:40 PM   #4
pro's Avatar
Thanks guys.
To this point, if not mistake, task that they go replaced in agreement also cap.C15 and C16.
Still a question.
Thoughts that replacing ghi IRF 610 with of the MPV3306, or the 2sk389 can go the same one well? I ask, why of these transistors I have some in house already of the selected braces, therefore I would avoid to buy of others.
Thanks again.
Old 18th May 2004, 02:04 PM   #5
Originally posted by pro
Thanks guys.
Still a question.
Thanks again.
Oups ! Yes you're right, I just forgot about the LP filter.. Just recompute the cap's values accordingly
Don't know the MPV3306. Same as Zetex' ZVN3306 ? If yes, it should work, but be careful about dissipation issues. I don't know either how it will sound with a 3306... Just test.
2SK289 should work too, but chose the right grade to withstand the bias current. In this case the gate voltage should be negative to achieve 0V at the source. Just check this thread for additionnal info :
I/U stage D1 clone with 2sk389 finetuned...
Hope this helps
Old 18th May 2004, 02:05 PM   #6
pro's Avatar
Hop! I am sorry.
I wanted to say ZVN3306A.
Old 18th May 2004, 04:50 PM   #7
Hop! I am sorry.
Works fine.
Old 26th May 2004, 09:20 AM   #8
pro's Avatar
One other question.
Because it's output will run in unbalanced mode, is a CCS needed in place of R26 and R33, or well therefore as it is.
Thanks.
Pro.
Old 26th May 2004, 11:56 AM   #9
Works well as it is . CCS isn't necessary but you can try it . IMHO the CCS changes a little the sound character , and gives to it the sensation of more articulation, but very little.
I just tried the buffers with P-channel ZVP3306A and works fine.
Old 26th May 2004, 12:14 PM   #10
pro's Avatar
Thanks Stefano.
Question about Pass D1 I/V output stage PatPet Digital Source 1 2nd July 2005 06:16 PM
PCM1704 + Pass D1 Output Stage? OliverD Digital Source 4 10th March 2005 08:45 AM
Nelson Pass-D1-DAC-Output-Stage with tubes ? Blitz Tubes / Valves 0 2nd January 2004 04:01 PM
Page generated in 0.10217 seconds (74.93% PHP - 25.07% MySQL) with 11 queries
