| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Banned
Rudolf,
In your schematic does AGRND connect to GRND through caps? What is the function of jumpers. With TDA1545 as the DAC you use J309s to provide 1mA bias current to IC and Output J309s - is this all that's needed here? I am about to implement this for a TDA1545 in a Marantz CD4000 - looking forward to hearing better sounds. Keep up the good work Rudolf John |
#12 |
GNDA acts as the +14.2V common for both channels. Didn't figure out a way in Eagle yet to use my own labels...
In stead of the +14.2V you can use GND as common, try it and tell us what you prefer. Jumper is just there because of my layout in Eagle. In fact I used the same pcb for the TDA1545A, I included the reference resistors and capacitor. I wouldn't use a current source at the dac's outputs, but just resistors from each output to the negative rail of -14.2V. Do install a 8.4672MHz low jitter clock (Elso Kwak's clock for example) in your Marantz. Connect it not only to the transport, but use it as BCK input to the DAC; BCK is running at the same frequency because of 4*(oversampling)* 2(channels)*24(frame width)*44.1kHz=8.4672MHz. This is much better than connecting it to just the transport. If not installing a seperate clock, do feed the 3 power pins on the SAA737X decoder chip with an individual supply; improvements are better than installing a low jitter clock to the transport only! |
#13 |
Banned
I've already had trouble trying to feed a seperate supply to the SAA7378 - the transport behaves erratically - spins v fast but does not sense disk, laser servo clicks, etc. - I believe this has to do with the documented delay needed between the 5V and 12V supply to the transport?
How have u overcome these problems? I have the KWAK clock schematic and will implement it when I get all the parts. What about asynchronous clocking of the DAC - have u tried it - is there a schematic available? Thanks for your help |
#14 |
Banned
Rudolf,
I've built your circuit into one channel of my CDP using the TDA1545A schematic and tried every which way to get it to work but no sounds. Can you explain - Is j309 source the pin that loops back to opamp with drain the pin that goes to output? - V+ can be GND - what is GNDA? - how to match jfets? - about waht is the correct value for resistor on J309 giving 1mA sink current? - Is opamp operating as DC servo in this config & J309 the amplification device? Hope these questions do not seem stupid but I'm stuck and was looking forward to the sound of this circuit Regards John |
#15 |
The fet's drain connects to the I/V resistor, its source to the dac output and feedback loop.
V+ is used as common (signal minus). You could use ground as common as well, though i would prefer V+ You don't need to match the fets and can take any n-fet that has IDDS of say 10mA and up. Opamp will drive gate of fet, so the voltage on the fets source stays at Vref. So the opamp acts as an active feedback and the fet is more or less a variable resistor with current gain of 1. I don't remember the exact Vref anymore (something like 3V), but it's safe to take a resistor of about 1k, this should sink a couple of mA which covers the 1mA output swing of the dac AND it's bias current. You can measure the actual Vref on the original opamp output stage, just measure the -input on the opamp. The circuit I have shown earlier does work, it's from the eagle pcb design package. I've installed it in two players (one with TDA1545A and one with TDA1543). The jfet output stage is also working in a player equiped with TDA1541A-S1... I do have one pcb left John, so if you don't succeed that's still an option. About the SAA737X; I fed the 3 power pins from seperate LM431 shunt regulator supplies that are never switched of. I also augmented some local bypass elco's on the transport and added a bypass elco for the laser supply. No problems. I'm sorry you're experiencing that many troubles John. Do check all voltages etc. before connecting the dac chip, since you could easily damage it.
Rudolf Broertjes |
#16 |
Banned
Rudolf,
Thank you for your prompt & comprehensive reply I am using this with the TDA1545A DAC (didn't explain this before) Please correct any of the following you find to be wrong I couldn't understand how the right channel had V+ as ground but not on the left channel. The GNDA are not connections to common ground (not connections at all simply symbols?)? I don't need CCS on DAC output just 1K resistor from each output to neg rail. I will implement your SAA737X power supply mods - can you help me with which pins I should supply ( should I also supply grounds?) Pinouts according to SAA7372 datasheet ( no info on SAA7378) 1 - Analog ground 1 2 - Analog supply 1 12 - Analog ground 2 16 - analog ground 3 19 - analog supply 2 30 - Dgital supply 1 for periphery 32 - digital ground 1 39 - digital ground 2 47 - digital supply 2 for periphery 49 - digital ground 3 56 - digital ground 4 59 - digital supply 3 for core From above analog supply 3 seems to be missing as does digital supply 4 ? As far as LM431 shunt reg - what is the difference between using 1K+1K, 2K+2K or 3K+3K, etc for 5V regulation? Sorry about all the questions regards John |
#17 |
GNDA in the circuit;
both (-)output are connected to +14.2 volts or so, just labeled GNDA (could be any label if I know how to do it in the pcb design program). SAA787X I did use seperate regulators for these. 2 - Analog supply 1 19 - analog supply 2 59 - digital supply 3 But I advise you not to touch them, since you're already experiencing many difficulties getting the output circuit to work. Success, Rudolf. |
#18 |
| Wtb: Tda1543 | leadbelly | Swap Meet | 0 | 19th October 2006 05:42 AM |
| TDA1543 dac | dariusku | Digital Source | 3 | 31st March 2006 06:38 PM |
| Tda1543 | fili | Digital Source | 5 | 25th December 2004 11:23 AM |
| Where to buy TDA1543 D/A | stan_33 | Digital Source | 32 | 7th May 2004 07:54 AM |
| TDA1543 Non OS DAC | jean-paul | Digital Source | 83 | 22nd January 2004 10:27 PM |
