Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th April 2004, 05:11 PM   #1
A 8 is offline A 8  Sweden
Default -100dB 16bit data through ASRC 24/96 dac -pics
I managed to get my hands on an oscilloscope and took a few pictures.
The measurements are done at the power amp output, the dac is a CS8420/DF1704/Balanced PCM1704K/ with passive IV conversion.
The spdif data originates from an old Pioneer PDS-802 fitted with another CS8420 set for 16bit in and 24/48 out.
The disc generating the -100dB and -90dB dithered data is an old test disc from HiFi News & Record Review produced by Martin Colloms.
I am not sure what I am seeing here, looking at the -100dB signal, are the PCM1704 switching the least (7) significant bits on and off or what....?
Any thoughts or insights are welcome!
/Michael
Old 29th April 2004, 05:13 PM   #2
That was the 16/44 -100dB data...
This is -90dB 16/44 data
BTW..there is no low pass filtering and the poweramp runs up to 500Khz
Old 29th April 2004, 05:41 PM   #3
tiroth is offline tiroth  United States
I don't know how you are inferring that from the pic (when you say -100dB do you simply mean digital silence?), but yes, the LSBs will be affected due to dither. The 16-bit signal occupies the top 16 MSBs so when dither is applied it affects the remaining LSBs for 24-bit output.
Old 29th April 2004, 05:58 PM   #4
-100dB refers to the -100dB test track on the disc, digital silence does not show the pattern I posted, it shows a flatline without the "spikes"
Old 29th April 2004, 06:01 PM   #5
Ok, that does make sense. It is probably just a few bits turned on periodically to make the DAC generate some output.
Old 29th April 2004, 06:24 PM   #6
Bernhard's Avatar
-100dB is very very low.
Philips used -60dB and I suggest a spectrum analyzer because the scope tells nothing.
Bernhard
Old 29th April 2004, 06:25 PM   #7
I was under the impression that the asrc would interpolate, creating intermediate values and not just re-sample the same value until the next one comes along?
Old 29th April 2004, 06:32 PM   #8
Default A spectrum analyser would be nice...
But I can not get to one, anyway I was trying to understand the bit transisions.
-60dB actually looked pretty nice though, smooth and "kind off" clean.
Not 100% sure but I think this was -80dB.
Old 29th April 2004, 06:34 PM   #9
It does, and I've watched AD1896 do it. Otherwise only 1 bit would change.
To see this easily, connect channel A to LRCK, channel B to SDATA (DOUT) and trigger on channel A. You can see each bit value this way, and the LSBs are clearly active.
If you have a third channel to display BCK it makes it even easier to see the transition points.
Old 29th April 2004, 06:36 PM   #10
Bernhard's Avatar
Originally posted by A 8
-60dB actually looked pretty nice, smooth and "kind off" clean.
And you won't recognize small distortions from looking at the waveform.
If it starts looking ugly, it already sounds very ugly.
100db, AMT and 4x BETA-8 +sub tinitus Multi-Way 33 27th April 2009 08:22 PM
100dB nbcd Solid State 5 17th January 2006 07:53 AM
New ASRC - TI SRC4192 tiroth Digital Source 1 27th August 2003 10:49 AM
ASRC Comparison ? ftorres Digital Source 4 20th February 2002 02:33 PM
Page generated in 0.11170 seconds (80.69% PHP - 19.31% MySQL) with 11 queries
