DAC alive - Page 9 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th May 2004, 03:37 PM   #81
Default RE: RMAA
I disagree. First of all RMAA is more flexible because we have the open source codes for measures, so you can do whatever you want with the programming.
Second - they use 1 kHz tone in the measurements of THD, then you can adjust the level - if you want it different then -3dB below FS, and get the FFT spectrum. Well, there is nothing to argue about, everyone prefer what he likes more.
Old 9th May 2004, 03:40 PM   #82
Banned
a) off topic
b) before you do statements like that, please try spectralab.
c) i would be happy with open source that gives me same versatility like spectralab, but did not find until now
Old 9th May 2004, 03:42 PM   #83
Bricolo is offline Bricolo  France
Bricolo's Avatar
I remember that a member here wrote about a linux spectrum analyser
maybe you'll find some sources this way
Old 9th May 2004, 04:33 PM   #84
Originally posted by till
a) off topic
a) sorry about that
b) I did, as well as WinMLS and EFT5.
c) you've found it - http://forum.rightmark.org/topic.cgi?id=4:480
Old 11th May 2004, 04:07 PM   #85
Default RE: measures
I forget to add - here is the test description:
http://audio.rightmark.org/downloads/tests.pdf
and here - are the sources for the measurements:
http://audio.rightmark.org/downloads/tests.dll.4.0.zip
Old 18th May 2004, 01:15 AM   #86
Banned
I want to try another section between the reciver and the DACs digital input. I want follow Jim W.s suggestion and use a isolational amp. Also i want get rid of the 74xxx chip.
would this work, or is a single ended inverter with higher ouput impedance ok here?
Old 25th May 2004, 04:00 PM   #87
Banned
next board for the DAC in progress
Old 25th May 2004, 09:29 PM   #88
Bernhard's Avatar
Doesn't iso amp have very small bandwith ???
Old 25th May 2004, 09:35 PM   #89
Banned
check the datasheet
DATA RATE: 80M Baud, typ
JBl GTS600, amplifier wanted! Dead or Alive, Alive if it can be helped:) Paradise_Ice Swap Meet 11 10th June 2013 02:02 PM
Its Alive ! ! ! Madmike2 Multi-Way 7 4th July 2005 09:20 PM
it is almost alive tenderland Tubes / Valves 5 23rd April 2005 10:10 PM
My first Nos dac is alive! setmenu Digital Source 23 23rd April 2004 01:59 PM
Its nearly alive... Jye Chip Amps 20 15th December 2003 11:06 PM
Copyright 1999-2017 diyAudio
