DAC alive
RE: RMAA
I disagree. First of all RMAA is more flexible :) because we have the open source codes for measures, so you can do whatever you want with the programming.
Second - they use 1 kHz tone in the measurements of THD, then you can adjust the level - if you want it different then -3dB below FS, and get the FFT spectrum. Well, there is nothing to argue about, everyone prefer what he likes more.
I want to try another section between the reciver and the DACs digital input. I want follow Jim W.s suggestion and use a isolational amp. Also i want get rid of the 74xxx chip.
would this work, or is a single ended inverter with higher ouput impedance ok here?
