Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Passive filter for DAC?
Old 30th April 2004, 11:58 AM   #11
Alien8 is offline Alien8  Belgium
Hmm, seems I was off a bit.
I was judging that based on the scope pics from the tnt site, I don't know the datasheet so I really couldn't say.
Thanks for correcting me John !
A8
If 'I' knew what I was doing, life would sure be easier...
Old 30th April 2004, 02:57 PM   #12
quantran is offline quantran  Viet Nam
Send a message via AIM to quantran Send a message via MSN to quantran Send a message via Yahoo to quantran
Hi John
What do you mean by "some form of differential summer"? Is there a way to do this using only passive parts?
Quan
Quan Tran
Old 30th April 2004, 03:03 PM   #13
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally posted by quantran
Hi John
Quan
you have to know the impedance -- but an RC filter will be of some help.
you might want to take a look at the FDNR (frequency dependent negative resistor) threads -- or the spec sheet for the AD713, or Burr-Brown (Texas Instruments) spec sheets on low distortion, low noise anti-aliasing filters.
Old 30th April 2004, 03:47 PM   #14
JohnW is offline JohnW  Czech Republic
JohnW's Avatar
The only way I know of to differentially sum with Passive components, is to use a transformer, but IMHO these are worst then opamps.
You could increase the order of the passive filter between the DAC outputs and the differential sum Opamp, there by reducing the “RF levels” seen by the Opamp input stage, then take the audio output directly from this Opamp - so there’s only one Opamp in the signal path.
I have always found the AD711 to be a well-behaved Opamp in the presents of RF.
See Cirrus Logic App Note AN48 for 2 Pole filter with differential input.
John
Time is my worst enemy!
Old 1st May 2004, 01:35 AM   #15
Thank you all for your valuable advices. It seems that one opamp on the signal path is unavoidable.
I've looked at the BB application notes for FDNR. It looks promissing and not too complicated for me to build. I have one spare pair of OPA2604. I will try it.
Quan
Quan Tran
Old 2nd January 2005, 03:28 PM   #16
klitgt is offline klitgt  Denmark
klitgt's Avatar
I would like to try to take the signal directly from diff. summing IC512 at pin 6 before R543 and leave out the LPF (IC513) and output buffer (IC514) completely in my Denon DCD3560.
But to avoid the worst HF I want to make a passive LowPassFilter. Can I do that just by replacing R544 with a cap? And which value should it be?
I plan to use OPA627 for IC511 and IC512. Any points of view on this project?
Passive filter for DAC?Hide this!Advertise here!
Passive BP filter sim results mashaffer Tubes / Valves 2 22nd June 2008 09:53 PM
Passive Shelf Filter Tenson Multi-Way 19 17th July 2006 09:13 PM
Is it possible: passive subsonic filter? Geez Subwoofers 7 9th August 2005 05:50 AM
passive filter for sub moi Multi-Way 34 28th July 2003 02:12 PM
