| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
I’m making a dsp project at the moment. I was wondering what type of filter signal graph is the better one – regarding truncating the numbers in internal registers of the DSP processor. The problem is that with the type 1 signal graph you can implement the difference equation in one go, keeping the numbers in the 32 bit register of the CPU right until the time they are sent to the DA converter. This however I find hard to do with the type 2 signal graph, since it needs 2 difference equations to work. My question is simply, witch signal graph is the better one for precision. Theoretically they describe the same system, but in real life there must be a superior type? Thanks \Jens |
#2 |
Type-1 is superior with respect to quantization errors at least with typical lowpass/highpass filters. However it needs more memory and more cycles than a type-2 implementation.
#3 |
Ok thanks, That's what i figured just needed to be sure.
I'll go for the type one equations then.... What about limit cycle oscillation btw? witch one would be better (Suffer less) \Jens |
#4 | |
#5 |
Hello,
I may have this up side down, but I understand limit cycle oscilation as the main factor that the IIR (infinite inpulse response) is called what it is. I belive it to be the noice generated by the algorithme thus making an oscillation because some of the truncation noise is feed back into the summoning point via the a1 and a2 coeffecients. \Jens |
#6 |
It can look like this with a step of ½ input.
\Jens |
#7 |
Your first graph is correct, but the plot does not look too good! You are correct that the Infinite in IIR is because of feedback through a1 and a2, but not because of self-oscillation due to quantization noise. When a1,a2 and y is quantized this may raise the noisefloor, but should not create oscillation.
Are you using fixed or floating point? How many bits? What are your coefficients? If your a1 and a2 are very small, you might want to do the -a1*y(n-1)-a2*y(n-2) in double precision. |
#8 |
Hello,
I have not implemented the signal graph on a platfor yet. All the work so fars is done on a PC in a mathprogram. I't a 6'th order system with high Q making a bandstop filter. The freq response is as planned, and it also stops the wanted freq when I sweep it. so it schould be ok i think. \Jens |
#9 | |
If you're using more than one Type I second order filter, you can use the denominator delays of one section as the numerator delays of the following section. Francois. |
#10 |
Hello Francois,
I'm note sure that I understand, can you explain it a bit further please? \Jens - not a DSP geek yet, but hope to be
| Re : BL type & GR type of transistor for Aleph-Ono | Arion | Pass Labs | 4 | 29th January 2007 06:15 PM |
| Ac filters | jleaman | Everything Else | 17 | 31st May 2006 07:45 AM |
| PI filters | Prune | Tubes / Valves | 3 | 26th September 2004 09:16 PM |
| Filters | Mr. Bungle | Solid State | 2 | 31st July 2004 05:08 PM |
| dsl filters | slackerbob | Everything Else | 1 | 22nd September 2003 12:20 AM |
| Page generated in 0.09066 seconds (86.56% PHP - 13.44% MySQL) with 11 queries |
