Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th April 2004, 10:35 PM   #1
Bernhard's Avatar
Question 1541 clock frequency
does the clock frequency have to be the weird 11.2896 MHz ?
Why is it the same for os and non os ?
Does the quality of the clock depend from the cristal quality ?
Bernhard
Old 20th April 2004, 10:42 PM   #2
TDA1540 is offline TDA1540  Netherlands
TDA1540's Avatar
The 1541 does not use 11,289MHz.
The 7210 and 7220 do.
Old 20th April 2004, 11:21 PM   #3
guido is offline guido  Netherlands
guido's Avatar
BCK:
non os (output 7210/7310)
44.1 kHz samplefreq * 32 bits/sample * 2 left/right = 2.8224 MHz.
4 x os: (output 7220)
4 * 44.1 *1000 * 16 (!) * 2 = 5.6448 MHz.
The 7220 needs the double freq for some reason (probably to control the in/out latches it needs more flanks), so thats
11.2896.
GuidoB
Old 21st April 2004, 06:37 AM   #4
Banned
Philips uses 256 * Fs, or 11.2896 MHz.
Yeah, the oscillator is in the filter, which is a bad idea form the jitter point of view. But you either feed it 2.8224 or 11.2896 MHz.......regardless of where the actual oscillator is.
The crystal is not as important as the supply feeding the oscillator circuit, and the oscillator itself. Once you have all those porblems addressed, you can start looking into better crystals...which will be expensive and diminishing returns.
Jocko
Old 21st April 2004, 06:49 AM   #5
Bernhard's Avatar
Ok, it's not going with another frequency, in any case the crystal has to be 11,2896 ?
Old 21st April 2004, 06:59 AM   #6
Banned
Yes.
Digital filters/DACs/SPDIF RXs/etc. work on:
192 * Fs
256 * Fs
384 * Fs
512 * Fs
The middle two bring the most common.
Now..........if you have a BB DF1704, and feed it 384 * Fs, it outputs 192 * Fs. But (o/s) CDPs use those two frequencies.
SACD......DVD...etc.......don't even ask. It is not so simple.
So.........be glad CDPs use only 2 "weird" frequencies.
Jocko
Old 21st April 2004, 09:57 PM   #7
RR is offline RR  Europe
RR's Avatar
Originally posted by guido
BCK:
11.2896.
Yes, I2S use to be 32 bits per channel in each word. Then it can acommodates data with more than 16 bits resolution. I think that this is standard but I'm not really sure.
Roberto
Old 21st April 2004, 09:59 PM   #8
RR's Avatar
Ooops, I meant 32 clock pulses.
Old 21st April 2004, 11:17 PM   #9
guido's Avatar
Roberto
No I2S can be any wordlenght!
7210: 32 (16 bits not used)
7220: 16
cd-pro output: 24 (think i read that somewhere).
GuidoB
difficulty with 1/2 clock to TDA 1541 tubee Digital Source 81 14th March 2008 02:25 PM
Rotel 961 clock frequency jarek Chip Amps 2 27th February 2006 09:40 PM
Changing the clock frequency Pboden Digital Source 1 22nd January 2005 04:08 AM
1541 passiv I/V idea & 1541 S1 found, no A ! Bernhard Digital Source 6 9th April 2004 09:18 AM
Multi-frequency clock mcs Digital Source 21 19th January 2004 10:36 AM
Page generated in 0.08654 seconds (87.27% PHP - 12.73% MySQL) with 10 queries
