Philips CD104 tweaks - Page 52 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th March 2008, 12:17 PM   #511
Send a message via ICQ to Sbrindolone
You reason is a capacitor.
You know more information about this special grundig ground?
If you do not know if, in italy many people talk about certain products grundig, saying that playing in a special way.
I repeat not all just a dozen products of a well-specified period.
Old 25th March 2008, 12:31 PM   #512
jives11 is offline jives11  United Kingdom
jives11's Avatar
so as I understand it the Grundig has a 2.2nF cap between the signal ground and the chassis ground. is that what we are saying the Grundig special ground is ?
Old 25th March 2008, 12:35 PM   #513
This is only a part of advanced ground technology in the best product of Grundig.
Quote
Old 25th March 2008, 01:00 PM   #514
jives11's Avatar
Quote
I'm sure you're right, but I still challenge anyone to detail what this mythical Grundig earthing arrangement is. I would buy a Grundig 7550 if my CD104 broke as I like the simple style of it, so I don't doubt it is a good player. I'd just like to see a picture or schematic which supports this view. I cannot see anything here which isn't 100% Philips but maybe the changes are hidden beneath the board or on the chasis end of the connectors ?
http://www.dcaudio.kgb.pl/grundig7550.htm
Old 25th March 2008, 01:08 PM   #515
I do not have the answers.
I have the cd104 and cd7550 look the same but the cd7550 sounds better.
I thought someone here had discovered why
Old 26th March 2008, 05:40 PM   #516
poynton is offline poynton  United Kingdom
poynton's Avatar
calling jives11
lost your email address.
please pm me.
Andy
Old 27th March 2008, 12:47 AM   #517
Please help I have Philips CD 304 it similar like 104 and I am put in non os follow this picture now I have very distort sound did I miss something or what please help
Old 27th March 2008, 09:37 PM   #518
Onnosr is offline Onnosr  Netherlands
Did you put the SAA 7000 in the 14 bit output mode by
putting pin 16 high ?
original in the 104 ( 304) the saa 7000 outputs in 16 bit mode.
You have to put the SAA7000 in 14 bit mode by disconnect pin 16 from ground and connect it to + 5 volt through a resistor of 1k
(FI to pin 18 = +5v)
The removed SAA 7020 takes 16 bit but outputs 14 bit and the TDA 1540p takes only 14 bit !!
Succes
Onno
Old 27th March 2008, 10:56 PM   #519
I am rush when I was working for that and I am forgot to disconnect pin 16 to ground. Works fine now Thanks
Old 3rd May 2008, 05:35 PM   #520
Originally posted by wojtek.l
Yes, this is capicitor. I know this solution. You can try 2n2 -10 nF also. Please to look at another Grundig equipment like v7000, v1700, v35 (also similar solution). This is only a part of advanced ground technology in the best product of Grundig.
Hallo,
could you please explain better how the "hf grounding" works.
Thanks.
Max
Philips CD104 Bob Roberts Digital Source 14 24th September 2004 03:25 PM
Copyright 1999-2017 diyAudio
