Philips CD104 tweaks - Page 25 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th May 2006, 01:07 PM   #241
JeroenR is offline JeroenR  Netherlands
Tube output is working... and not.
I added the tube stage after the 1540 (see diagrams posted earlier). Good news is that there is music and so dar as I can judge it is ok. Bad news is the additional sounds...
With additional sounds I mean :
- lots of hummmmmm...... well, that should be not too difficult to solve, perhaps the transistor schema suggested before. Or... Humm due to incorrect heater supply?? I noticed that the 6,3V supply does not give more then 5V!!! I need a bigger TX, the 6V 800mA probably gives not enough room for the TL1085.
- digital noises; When I press play there is this "weewee plop plop buzzzzz" before the music starts. The weewee plop plop stops then but the higher buzzzz continues through the music. It is like R2D2 does an intro before the music starts and then wisstles along.
The digital noise must be due to 2 things; first the removed muting stage, well nothing to do here I guess as that is gone forever and second the lack of filtering (except for the RC 22ohm/150nF after dac).
I can live with R2D2 doing the intro's but I want to get rid of the higher buzzz. Would anybody have a suggestion for a better method of filtering between dac and tubes?
Thanks,
Jeroen
Old 28th May 2006, 01:23 PM   #242
poynton is offline poynton  United Kingdom
poynton's Avatar
Thanks,
Jeroen
Hi.
Hum possibly due to heaters or maybe the HT supply.
Try a battery supply for the heaters or disconnect while playing to see if the noise disappears.
Add more capacitors to HT.
It may also be due to too much current being drawn causing a drop in voltage - use regulator for lower HT as per my previous post.
For filtering, see Thorstens circuit for other dacs and adapt the filter [ use choke etc] He has posted a revised circuit I believe.
Cheers for now and good luck, JeroenR, I will be away now for 5 weeks or so.
Andy
Old 28th May 2006, 01:39 PM   #243
Originally posted by poynton
Hi.
Andy
Hi Andy,
Thanks again.
Have a great time on the Azores.
I'll keep posting.
Jeroen
Old 26th August 2006, 03:53 PM   #244
Geoff is offline Geoff  United Kingdom
Default CD104 Service Manual
It would appear that several participants in this thread have a copy of the CD104 Service Manual.
I have just been able to replace the CD104 that I foolishly scrapped about ten years ago(before I had web access and was aware of the mechanism it uses) and as I am sure that the replacement will benefit from some care and attention (replacement electrolytics etc) I would be very grateful if someone could send me a copy of the Service Manual (and any other relevant information). Please email it to :
mail DOT tcaas AT btinternet DOT com
Thanks in anticipation,
Geoff
Old 26th August 2006, 06:03 PM   #245
jives11 is offline jives11  Europe
jives11's Avatar
glad to but 12Mb zipped !
if you have the quota then you should have mail by now. If not I'd guess your ISP doesn't allow such large attachments
Old 26th August 2006, 06:43 PM   #246
Files received. Many thanks. A little light reading for me this evening!
Old 26th August 2006, 07:12 PM   #247
Bernhard's Avatar
The best tweak for a CD104 or CD304 would be to upgrade to a CD304mkII DAC board ---> 16 bit + digital out.
Old 28th August 2006, 01:20 PM   #248
Could someone please send me the service manual so that I can continue my tweaks for the 104?
henkjohan "at" hotmail "dot" com
btw, this is my player so far
http://midiserver.student.utwente.nl...104/cd_104.htm
Doe iets goed, of doe het niet.
Old 28th August 2006, 01:51 PM   #249
jives11's Avatar
you have mail
Old 28th August 2006, 02:51 PM   #250
jives11's Avatar
Originally posted by jives11
you have mail
ah no. one servicing guide made it, but the schematics didn't due to being 12.5Mb zipped. any other way to get this to you ?
Philips CD104 Bob Roberts Digital Source 14 24th September 2004 04:25 PM
Copyright 1999-2017 diyAudio
