Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips CD104 tweaks
Old 16th May 2006, 06:32 AM   #211
weissi is offline weissi  Austria
I would appreciate it if someone would fill my mailbox with a cd104 .pdf (service manual.....)
please send to " blomquist>remove this<@gmx.at "
THX alot.
regards / servus
Old 16th May 2006, 06:44 AM   #212
jives11 is offline jives11  United Kingdom
jives11's Avatar
THX alot.
should be on it's way but is 12Mb zipped.
Old 16th May 2006, 07:09 AM   #213
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Re: Re: This may work ........
Originally posted by JeroenR
Hi Andy,
I'm going to try your circuit this weekend.
I'll try to deal with the ripple later, first thing is getting the 100V from the player's transformer.
Thank you very much for the help. I'll let you know about the results asap.
Jeroen
Hi.
So what happened?
Andy
Old 16th May 2006, 08:15 AM   #214
JeroenR is offline JeroenR  Netherlands
Default Re: Re: Re: This may work ........
Originally posted by poynton
Hi.
So what happened?
Andy
I spent a lot of time enjoying the sun and jazz-weekend. It was scorchio and the music great.
There was time to build the supply but no time for the test, photo and update of tube-diagram. I hope I can find time one of the evenings to post some results.
Old 16th May 2006, 09:12 AM   #215
Thanks so much, but I'm afraid the file is only 8Mb and it seems it doesn't work. Nevertheless, I appreciate your help. regards, Markus
regards / servus
Old 16th May 2006, 10:32 AM   #216
jives11's Avatar
Hmmm, odd, it's a valid 12Mb PDF file in my googlemail sent folder. Are you sure you have downloaded the full attachment ? Most ISP's will not accept such a large attachment, but I didn't get a 'bounce message'.
anyway, no matter, I have sent a new mail with a different way to get the file
Old 16th May 2006, 11:58 AM   #217
ahhh, now it works. Have a nice day & thx
regards / servus
Old 17th May 2006, 09:06 PM   #218
Hi.
So what happened?
Andy
Hi Andy,
It works.
I measured 151.8V on the output.
The place of the supply looks a bit strange but there is the constant struggle for space inside the 104.
Saw today a CD104 offered on Marktplaats (Dutch EBay) for 100 EURO!!! I should be carefull with my 104, replacements are getting expensive I guess.
I will update the tube diagram in a few days and post.
Jeroen
Old 17th May 2006, 10:07 PM   #219
poynton's Avatar
Default Re: Re: Re: Re: This may work ........
Hi Andy,
It works.
Jeroen
Hi.
Is that the 150v supply on the heatsink ??
looks good if it is .
Andy
Old 18th May 2006, 09:02 AM   #220
Default Re: Re: Re: Re: Re: This may work ........
Hi.
Andy
Yep, That's the one.
I used 47mF/160V caps as I was expecting 100V, not 150. Bit tight this way but at least it keeps the supply small. The red wire is the V-out. It is slightly boxed (alu) because it is close to outputs and the decoder/servo boards.
The decoder board is now empty where the opamps etc were. I hope to have just enough space for the tubes, caps and more caps...... and let's not forget the 6.3V supply.
Philips CD104 tweaksHide this!Advertise here!
Philips CD104 Bob Roberts Digital Source 14 24th September 2004 03:25 PM
