Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Is this a real TDA1541A?
Old 28th April 2004, 10:21 PM   #41
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
If you ask me, SAA7220A + TDA1541A is not good.
Better stay with SAA7220A + TDA1541.
I also do not like SAA7220B with TDA1541 /A.
With non os 1541A is better.
But ask jean-paul...
...or use the search function.
Old 28th April 2004, 10:33 PM   #42
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Default Re: hi
Originally posted by gio_b
hi jean_paul
so, my I replace my old 4 op 5534d with 4 new opa627,take care of capacitor to be removed as you told me,and nothing more?
is 5534d 1 op or 2 op?
and opa627 is 1 or 2 ? is it a full equivalent...?
opa627 is 24 each....
so I prefer to be sure.
thanks
Please always check datasheets as they can be found at the manufacturers sites. One important parameter is max. supply voltage ( among others ) if you replace NE5534 opamps for other types. NE5534 can take max. 22 V which is rather exceptional. So check supply voltages when you replace NE5534. In some cdplayers ( Marantz CD80 for example ) an opamp is used for DC servo purpose. You can leave that one ( mostly LF411 ) where it is if a cdplayer has one.
NE5534 is a single opamp and so is OPA627. No problem whatsoever except for the 22 pF cap that needs to be removed.
Old news but a new clock will help a lot. Check the various threads on the subject.
Using the Search function is good advice as many things tend to be repeated several times which "pollutes" the space on the precious server ( something some people don't seem to get, only the sun shines for free ). IMO it is a bit selfish to expect people will answer your question that has been posed 10 times before just because you don't like to do put some effort in it. It is also good to read the other info in those threads that may not be repeated again in a new thread.
I prefer TDA1541A and SAA7220P/B but that's just me. I listen to the chips, not to an analyzer. I also don't mix up TDA1541 with SAA7220P/B and TDA1541A and SAA7220P/A but that's just me.
It's only audio. Member of the non modular PCB design committee
Old 28th April 2004, 10:44 PM   #43
Bricolo is offline Bricolo  France
Bricolo's Avatar
Jean-Paul,
I know it's not the topic here, but what cap do you advice for the DEM cap (470pF) ?
Old 28th April 2004, 10:47 PM   #44
jean-paul's Avatar
I have no advice on that as I leave the originals ( 680 pF in reality ) where they are if they're styroflex/KS.
Old 29th April 2004, 07:07 AM   #45
Bricolo's Avatar
It's for a new DAC, so there's no original one
The good thing is that I cand find styroflex in Strasbourg. 0.60, I don't know if it's expensive or not.
Old 4th May 2004, 09:56 PM   #46
gio_b is offline gio_b  Italy
Default hi
any pohotos on how to remaunt the meccaniasm of cd 960 phiips?
i replace all 4(four)belt (non philips)but dosen't work any way.the belts shifts on the weels ,and the mouvment in non complit...so dosen' load the cd...
any halp...
thanks in advice.
ciao ciao
Old 5th May 2004, 04:42 AM   #47
jean-paul's Avatar
Please rewrite your post in english everyone can understand.
You can edit your own post after posting for some time which gives you the ability to rethink/rephrase what you want to say.
Old 5th May 2004, 05:46 AM   #48
Bernhard's Avatar
jean-paul,
you should become a moderator
Old 5th May 2004, 03:21 PM   #49
jean-paul's Avatar
You should know better by now
Old 10th May 2004, 05:56 PM   #50
Fabian is offline Fabian  Switzerland
Default TDA1541A ordered from Reichelt
I ordered a TDA1541A from www.reichelt.de for replacement of TDA1541 in my Philips CD650. After reading this thread I see that I obviously received the non A version, am I right?
Fabian
Is this a real TDA1541A?Hide this!Advertise here!
Is this a real TDA1541A? pop11 Digital Source 1 24th August 2006 07:16 AM
tda1541a-s1,real or fake daniu Digital Source 0 5th July 2004 01:14 AM
