Is this a real TDA1541A? - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th April 2004, 10:57 AM   #31
pop11 is offline pop11  Canada
Dear Henk,
Did you ever come across TDA1541AT/C1?
This claims to be a SMD version of the TDA1541A, and they are quite readily available, similar price to a normal TDA1541A, and use the same datasheet.
Sorry that I don't have a picture for it.
Many thanks.
POP11
Old 27th April 2004, 11:40 AM   #32
diyAudio Moderator Emeritus
jean-paul's Avatar
Default Re: tda1541 to 1541a
Originally posted by gio_b
I have a cd 960 philips with a TDA1541 non Philips. Can I replace it with a good Philips TDA1541A ? Does it play better ???
Please use the Search for that info, it has been discussed more than once:
http://www.diyaudio.com/forums/search.php
OPA627 is an excellent choice but remove the compensation caps ( 22 pF in general ) from pin 1 to 8 as OPA627 is compensated internally.
It's only audio. Member of the non modular PCB design committee
Old 27th April 2004, 07:16 PM   #33
Bernhard's Avatar
i have a cd 960 philips with a tda1541 non philps.can i replace it with a good philips tda1541A?does it plays better???
and more....
in 960 there are 4 op 5534d jrc 6216 for analog signal,can i replace with other equivalent...opa627 ad860 ad826 are good??
ciao ciao
Do you have a picture ???
TDA1541 without A ???
Old 28th April 2004, 12:37 PM   #34
gio_b is offline gio_b  Italy
Unhappy hi
no picture yet
TDA1541
3593
HSH8710 5Y
no logo philips
Old 28th April 2004, 05:08 PM   #35
chlo is offline chlo  United Kingdom
Iíve swapped in SA22..P/B and TDA1541A S1 in my Philips CD960 sounds better and still using at the present time!.
Regards.
Old 28th April 2004, 05:57 PM   #36
HtP is offline HtP  Netherlands
Originally posted by pop11
Dear Henk,
Many thanks.
POP11
Sorry, I have never seen it.
regards,
Henk ten Pierick
Old 28th April 2004, 07:15 PM   #37
Bernhard's Avatar
Default Re: hi
no picture yet
TDA1541
3593
HSH8710 5Y
no logo philips
This is old version and it is normal that it has no Philips logo.
But: Shouldn't be a 1541A S1 inside CD960 ???
SAA7220A or SAA7220B ?
Old 28th April 2004, 07:25 PM   #38
Bricolo is offline Bricolo  France
Bricolo's Avatar
Dear Henk,
Many thanks.
POP11
where did you hear about them?
Old 28th April 2004, 08:23 PM   #39
Default thanks jean_paul and bernard
because of raptus i remove all conponents(cards) from my cd960..
(for a better maintenence,spring belt..etc...etc...).
i ll try to remount all with new(4) op by jean_paul and i tell you how it sonds(if it).
so,if i replace the tda1541,this is the version i have, with tda1541a sounds better?
i also have saa7220p/a
84080
csg8644m2 (?)
Old 28th April 2004, 09:49 PM   #40
Default hi
hi jean_paul
so, my i replace my old 4 op 5534d with 4 new opa627,take care of capacitor to be removed as you told me,and nothig more?
is 5534d 1 op or 2 op?
and opa627 is 1 or 2 ? is full equivalent...?
opa627 is 24Ä each....
so i prefer to be scure.
thanks
Is this a real TDA1541A? pop11 Digital Source 1 24th August 2006 08:16 AM
tda1541a-s1,real or fake daniu Digital Source 0 5th July 2004 02:14 AM
Copyright ©1999-2017 diyAudio
