| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#381 |
This raises an intresting question: Is the single/double crowns THAT much better? I mean good enough to justify around or well over USD100?
#382 | |
Its almost like buying a myth
http://www.dutchaudioclassics.nl - info on Philips TDA1541 based cdplayers |
#383 |
When I built a TDA1541A DAC, I put two chips in parallel. Paralleling several chip is an old tried and tested technique for reducing inconsistencies by averaging out the measurements across the chips and flattening (making more consistent) the response. Having a double crown eliminates the need to do this, as the double crown has no notable inconsistencies. It is for those that want the top 1% of measured chips and to to eek out every last bit of consistency across the spectrum from this chip and related designs.
Lucas |
#384 |
I'm trying to design a dac with 4xTDA1541A, fed by normal/inverted signal.
The intention is a 2+2 (balanced + parallell) TDA1541A dac. |
#385 |
#386 | |
#387 |
diyAudio Moderator Emeritus
By now one should suspect any S2. I would not buy these.
It's only audio |
#388 |
#389 |
Complete fake
-------- TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling |
#390 |
Any dutch forum members from vlaardingen?
| Is this a real TDA1541A? | pop11 | Digital Source | 1 | 24th August 2006 07:16 AM |
| tda1541a-s1,real or fake | daniu | Digital Source | 0 | 5th July 2004 01:14 AM |
