| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 | |
Question to Bernhard: why are you so sure that is must be fake? regards,
Henk ten Pierick |
#22 | |
I was just kidding, note the in my post, because Jean-Paul likes to suspect fakes But now as you ask... I have 1541 with 3944 batch and 8718 date code. Also I have 1541A with 10795 batch and 8801 date code. This chip is 4184 batch and 9727 date code, so could be 8727 date code and printing error. But all my 1541 including S1 have 5Y beside date code while my 1541 A has 2Y and my 1541A S1 without silvercrown from CD880 and S1 silvercrown bought in shop have 2 without Y. But this chip got 5Y and pretends to be an A. Also all my 1541A have Philips logo. Is it a new perception that 1541A S1 have no Y ? So if there is the Y, it is a fake ??? Question to you as you seem to be an expert: What you think about using passive I/V conversion with floating ground for the TDA, driven by the TDA's output voltage, buffered with opamp ??? |
#23 | |
Aswer to your question: 1. It is active I/V conversion, not passive conversion. 2. At the analog output very difficult, at least more difficult than normal active I/V conversion. 3. It will introduce signal dependent delay for the digital data, including the BCK. This will give frequency modulation to the spectrum. How much depends on the rise time of the digital signal, and the amplitude of the analog signal. 4. It will sound very interesting but I do not think that you will like it. regards,
Henk ten Pierick |
#24 | |
diyAudio Moderator Emeritus
Bernhard, it is economically not interesting to produce fakes so you won't likely find such chips. Remarking gives profit without much costs. They are around these days driven by the hype/facts about TDA1541A.
It's only audio |
#25 | |
What you think is suspicious ? |
#26 |
Perhaps someone could shed some light on the background to this fake/not fake saga and where this thread in general is heading.
Are you i.e. the accusers suggesting there is some kind of backdoor operation going at TSMC after hours or perhaps some questionable east European types are breaking into the Infineon or Atmel fabs at the weekend and knocking off a few TDA1541AS1's? Afterall, semiconductor fabrication plants are not the sort of thing to be found in a hobbyist's garage. ray. |
#27 |
Some people remark old but NOS TDA1541 chips with the marking TDA1541A-S1 to gain higher profits ( TDA1541 = 3 to 6 euro, TDA1541A-S1 = 40 to 50 euro ). Not such a strange phenomenon when you think of rebranded 2SA1302, rebranded Intel & AMD CPU's and others.
A bit like the chip in post #1.
It's only audio |
#28 | |
#29 |
You can have whatever branding you want on chips you buy from me
![]() Y marking costs 50 cents extra.
It's only audio |
#30 |
i have a cd 960 philips with a tda1541 non philps.can i replace it with a good philips tda1541A?does it plays better???
and more.... in 960 there are 4 op 5534d jrc 6216 for analog signal,can i replace with other equivalent...opa627 ad860 ad826 are good?? ciao ciao |
| Is this a real TDA1541A? | pop11 | Digital Source | 1 | 24th August 2006 08:16 AM |
| tda1541a-s1,real or fake | daniu | Digital Source | 0 | 5th July 2004 02:14 AM |
| Page generated in 0.11083 seconds (87.86% PHP - 12.14% MySQL) with 11 queries |
