This one's cheap enough to be able to ignore the DAC - https://detail.tmall.com/item.htm?spm=a230r.1.14.9.5f17766aYw5izv&id=45702123211&cm_id=140105335569ed55e27b&abbucket=16&skuId=104953748262
Perhaps too long ago for the OP to be useful but here is another reasonable cheap one that I use as transport.
SHANLING TEMPO EC1B CD HDCD player HIFI EXQUIS read USB key Coaxial Optical|player psp|player torrenthifi mp4 - AliExpress
The Shanling Tempo EC1B
The transformer was noisy so I put some bitumen like dampening under it and on the very thin metal lid as well.
Ran a bit warm so I removed all 3 op amps and that helps some.
Reliable so far
Uses the Sanyo DV34 mechanism perhaps the same as Pro-Ject uses in their all metal version.
Transport is quiet when running not so when loading.
Hope this is of use for someone!
Reliable so far
