Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips (Marantz) CD-60 not spinning up
Old 21st June 2018, 11:31 PM   #91
hollowman is offline hollowman  United States
hollowman's Avatar
Default Conspiracy theory
Originally Posted by leadbelly View Post
I still can't believe you ate up all this bandwidth and time of the generous experts here and never mentioned you had DIY perf board circuit mods, hanging by their wires, that took a ride through the fall.
Hey, bellz... I'll let you reply to that:
"Conspiracy theory" ... yeah, that's it. You betcha, toots.
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 22nd June 2018, 06:54 AM   #92
Mooly's Avatar
Have to agree. We were short-changed on information that was relevant.
Old 22nd June 2018, 06:59 AM   #93
percival007 is offline percival007  England
Did you post this pic on this thread? Have quickly scanned all 8-9 pages and don't think you did.
Might have helped us if you had.
P.
Old 22nd June 2018, 08:52 AM   #94
bram jacobse is offline bram jacobse  Netherlands
bram jacobse's Avatar
Old 22nd June 2018, 03:34 PM   #95
hollowman's Avatar
P.
Those modules were unrelated to the spinning issue. Introducing them into the conversation would've complicated things: introduced wild, pointless tangents. Not that you folks didn't come up with many.
Nota Bene: the guy at the eevblog nailed the noise issue BEFORE that image was posted. See the eevblog thread
IAC, the CD60 experienced multiple issues after it fell. The main one being the subject of this thread.
I think DIYA is project forum, not a troubleshooting forum. So my bad in pursuing the matter here.
Old 22nd June 2018, 04:14 PM   #96
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
You are slagging this place after what you just did to these guys? I still can't quite believe it. I think you might just have won some award on this forum.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 22nd June 2018, 05:55 PM   #97
Don't think he's slagging off the Forum.
Still, would've been nice to have ALL the information at the beginning of the thread. And I did keep asking for a recording !! ;-)
P.
Old 22nd June 2018, 06:05 PM   #98
anatech is offline anatech  Canada
anatech's Avatar
Hi hollowman,
Given information and time, the folks do a pretty credible job of troubleshooting here. But some of us get pretty busy and have limited time to devote to a problem that comes with a minimum of information.
The fault you had would have been easier to fix had it been on my bench rather than an internet conversation. Here you are talking to a bunch of technicians and engineers who designed with the parts you are using. But without pictures and a complete description, how can you expect them to put in a bunch of time for you?
In the end, I actually did point you in the right direction and also told you I would have to see it to do any more than guess. That was your cue to cough up some detail. You didn't. Instead you found more information both on this web site and others - to your credit. But instead of letting us know what you found it became game time.
Most folks are gainfully employed and have to assign their time intelligently. Fixing someone's problem with scant details won't rate very high on anyone's list as the chance of a correct diagnosis is only slight.
Thank the folks who are helpful and try to maintain a realistic picture of what you are asking of others.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 7th July 2018, 04:03 PM   #99
hollowman's Avatar
Default An update ... and a puzzling anomaly
No repair job is worth its salt w/o some account of the device's long-term reliability.
Over the past few weeks, I've put over 12 hours of use on the CD-60.
All in all: no issues .... as if the accident never happened ...
...except for one anomaly.
Recall the last problem to troubleshot was low-level noise issue. It was related to DEM reclock circuit attached to the TDA1541A's pins 16/17. This was typical DIY project, that has been discussed in various threads, such as this.
That DEM ckt project replaced the stock 470pF cap. I had the Henk variety installed pre-accident. The project ckt is what caused the noise; installing the orig. cap solved the problem.
Here's a mystery:
That Henk DEM 'scopes out fine.
Not only that, I can no longer get other DEM ckts (like tubee) to work with CD-60.
Before accident, both Henk and tubee worked with the CD-60 (and led to improved sonics compared to orig. cap, as intended).
If you look at the Henk and tubee ckts, you'll note they are quite different designs (e.g., Henk requires +6, -6, +5v; tubee requires only +5v).
Like the weird laser power mis-calibration -- caused by accident -- the DEM mystery is spooky!
Old 7th July 2018, 05:00 PM   #100
Default ;-)
Have you asked on your other Forum?
Philips (Marantz) CD-60 not spinning upHide this!Advertise here!
Marantz CD63 disc not spinning lowfi1 Digital Source 3 16th April 2013 08:25 PM
Marantz cd-63 cd spinning anticlockwise? zoesdad Digital Source 6 15th March 2010 10:42 PM
Best Philips/Marantz CDP? homer09 Digital Source 6 24th April 2004 07:57 PM
Philips or Marantz ????? ernie-hol Digital Source 7 9th August 2003 01:48 PM
